good afternoon gentlemens. it is warm enough that i should wash my truck, especially the inside. i haven't cleaned the inside since i bought it, and there is probably a yard of mud and gravel in it, mixed with manure and sawdust.
i will probably just boil some sap though.
im so bored with this paper id probably wash your truck if you brought it over
just kidding i really should be getting this done so i can go back to vt
i was going to call them as well however i do not think they are capable of handling something that big. i know they have a very large shear, and bandsaw that can handle wide things but not 30" diameter. ill find out tomorrow. it would be great if they could, the auger is in newington.
We used Johnstone in North Haven for big and bizarre stuff.
logan was a definite no. magna said he can do up to 21" but wouldnt try to run the band down angled flights. the guy at winnick is communicating with his large steel people (dont normally deal with public) and is optomistic they would be able to do it. i will have to check out johnstone.
Just what are you trying to do to the auger Aaron?
the bottom of it is so terribly torn up, with repairs on top of repairs, we want to cut it up into fresh "straight" auger and weld new teeth onto fresh straight edges.
