Afternoon all! Sitting back, getting ready to watch the race... just (finally) sold the plow from the F150 so that's out of my hair finally! Still debating on using some of the money to order an exhaust or not... or just putting it all towards a plow for this truck.
I stopped by the nearest Ford dealer today, and found "my" truck! It was an "XL" model with none of the extra stuff that I don't need. It was forest green, extended cab, 8' bed, gray cloth interior, rubber floors, manual transfer case, manual locks, manual windows. When something breaks, it's a quick easy fix. 3.73 electronic locking rear, which is fine for me as I won't be towing all that often. 6.2L, auto. And I can actually see the ground from inside the engine compartment! It's a miracle! The only things that would have to change are the wheels/tires, and manual lockout hubs for the front. Somebody forgot to lock the passenger door on it, so I got to hop up in and open the hood and check it out. Too bad it ain't gonna happen! HA!
wow sounds like a good find man. sounds like my kind of truck.
good evening everybody. today i cleaned the garage then started putting the big cams in the mustang. i didnt really get much done, i just took the coils, injectors and fuel rails, and valve covers off so i could see if it has bolt or pressed on gears.
i need to wake up in 4.5 hours. i am not tired AT ALL. this is not good.
