- will a 9 inch from a 78 fit in an 82 with a 9 inch also.
- 90 f 150 aod
- tranny probs...
- Need help getting 9" axle shafts out!
- I have 2 ATF change options ,which is best?
- Bearings and seals in ford 8.8
- Help........9" axle
- Any AOD rebuild kit recommendations?
- Major Rear End Upgrade
- Another E4OD owner
- question about parts
- Dana 60 ball joints
- 96 tranny question
- Limited slip or not
- ZF 460 Transmission behind a 351M/400
- 1990 AOD 4x4
- Bell housing??
- Funky clutch
- Axle question
- 6.17 gears are weak?
- Transmission slips when accelerating from dead stop
- Dana 60 Carriers
- Will transfer case fit
- E4OD - How to test the MLPS??
- Questions about overdrive
- Correct/Best transmission & diffy fluids for 79 f250?
- 89 m5od concentric slave cylinder swap?
- Transmission shifting hard
- Rebuild C4 or go C6?
- Column Shift Transmission???
