Another E4OD owner
Old Sep 30, 2004 | 09:43 PM
bung's Avatar
bung
Cool Another E4OD owner
I had my trans rebuilt last year because of hard shifts and slipping. It has started shifting hard again. I have read most of the E4OD posts but there is too much info. I decided to start cheap and get the NEUTRAL SAFETY SWITCH. When I got home I noticed that the NSS on the rebuilt trans looks to be new. What other possible fixes are suggested? I'm not going to take the truck back to the guy who rebuilt the trans because he can't seem to find a problem. He says that he can't even get it to reproduce the shifting problems.
Old Oct 2, 2004 | 10:36 PM
bung's Avatar
bung
An update:
I bought the new NSS but discovered that it was replaced with a new one when the trans was rebuilt. I got under the truck and unplugged the NSS because I was going to remove it. I decided against doing that and plugged it back in. The next day the trans shifted MUCH smoother. The trans wouldl start shifting hard at the same spot on my commute to and from work every day. I kept expecting the violent shifts but they never happened. I did have a few firm shifts but nothing near as bad as the day before. I told my mechanic about this and he said that the NSS should have no bearing on how the trans shifts. It seems to be working fine now but I'll see how long it lasts.
Old Nov 16, 2004 | 02:56 AM
hipropos's Avatar
hipropos
So is the truck still shifting correctly. mine was doing the something.
I pulled the plug and cleaned it with electrical cleaner, and put electrical grease in it. its been shifting great and your mechanic is wrong.
The NSS has everything to do with it shifting correctly.
Old Nov 16, 2004 | 03:12 PM
95_4x4_jay's Avatar
95_4x4_jay
1995 4x4 f150
300 I6
4EOD
I am new to f150's as I have only had it a week.
Mine bucks/clunks when going into drive but seems to shift smooth through the gears when driving.
I am taking it in for a tranny service (fluid,filte,gasket) but is there somethingelse I should do.
I have used LUCAS tranny supplement before and felt a difference.
Old Nov 17, 2004 | 01:39 PM
Ironpants's Avatar
Ironpants
95_4X4_jay.
When you hold the brake and shift to any gear, do you hear and feel the clunk?
Check the driveline for a worn out u-joint.
That is usually not a tranny issue (clunks when initailly placed in drive gear).
Old Nov 17, 2004 | 01:45 PM
95_4x4_jay's Avatar
95_4x4_jay
Yeah. I hear it like this.....(when stopped of course)
Automatic tranny.
Park to reverse - nothing much (sounds and feels normal)
Park to drive - CLUNK
reverse to Drive - CLUNK
Drive to reverse - smaller Clunk
The harder I hold the brake the smaller the clunk.
I never have checked Drive 2 and Drive 1.
I am taking the driveshaft off this weekend to replace the tranfercase seal. I will play with the u-joints to see how free moving they are. i noticed that they have grease nipples. Should I replace or grease if they are stiff?
Thanks for the reply.
Old Nov 17, 2004 | 02:10 PM
gatesj's Avatar
gatesj
Grease your slip joint too. Apparently this is a common problem when they get sticky.
forensicpsyguy
Nov 24, 2019 02:59 PM
danlee
19
Jul 6, 2013 11:11 AM
54 Oldsman
Mar 20, 2010 05:33 PM
forensicpsyguy
Feb 14, 2010 03:38 PM
RLKBOB
Nov 6, 2004 10:29 AM
