- 390 engine build
- .020 or .030 over on 360?
- Pictures 351c, 351w
- this thing is a slug 2006 4.6
- I have one hell of a nutter butter of a crazy idea...
- Why would you De-stroke a truck engine?
- Fresh rebuild on a 351W blowing oil out of the rear - help please!!
- Total Ignition timing
- Advice for building a 460
- Im stuck.....
- needle cam bearings
- 93 F150 5.0 EFI Speed Density Engine Build
- Regular fuel to Racing fuel???
- AN Fitting sealer?
- increased torque help
- Dohc 300 I6
- Tune-up Specs
- AFR HEADS on 393
- 361 low power
- Shortys vs. longtubes
- roller cam and distributor gears
- 289 HiPo
- How to test a harmonic balancer?
- door knocking
- 351 buildup Help!!!
- too much cam??
- roller lifter valve train modifications (please read)
- advise on balancing 393 stroker-clutch gone
- adjusting vacuum advance
- making an engine spin to rpms sooner
