- Question on EGR Position Sensor
- New Ignition Module
- Harmonic ballancer removal?
- Iron GT40P heads Question
- newbee here. 1994 302 spec question
- no more 6!
- Chip or Headers?
- ignition
- conversion
- Engine rebuild (novice question)
- If you have interest in a supercharged 4.6 or 5.4..
- Bearing or lifter noise?
- 215/224 cam in stock 5.8
- Scary looking spark plugs
- crankshaft thrust bearing problem
- Any Ford V8's with the distributor in the rear?
- Strictly V6 performance...
- Airforce one intakes?
- New Coil and larger spark gap.
- egr valve on 94' 4.0
- is 114 lobe sep too much? speed density
- 99 4.6 L V8 Performance Upgrades
- Ignition Parts - Coils, Aftermarket or Motorcraft?
- What would your thoughts on this be?
- the engine formula
- I need power!!!
- help with rebuild 351w
- spark plugs
- A tip on setting your timing
- FYI on b&m roots blowers and carbed 351 windsors
