Sluggish acceleration at first
Old Sep 20, 2015 | 01:54 PM
Brian Hughes's Avatar
Brian Hughes
First post!
I've decided to tackle some of the issues I've been having with my 2001 F-150 5.4L XLT. There is one issue that I haven't been able to solve yet, though. When I start the engine, I get a really bad hesitation for the first like, 1 to 2 minutes then it clears up and seems fine. On occasion I'll get a flattening out of acceleration then I have to floor the gas till it clears up which is usually right away. The engine starts great and shuts off great.
A little background of the weekend:
I had a bunch of codes of read and I addressed the easy ones. I had an Air temp sensor error which I replaced as well as the cam shaft position sensor. When I did that, the engine quieted down a bit. Before I did that, it shaked pretty badly on start. I had to let it warm up for about 2 minutes before I could drive it. It almost stalled but never did. I thought it would clear up the hesitation issues but didn't.
I wanted to get the codes cleared after I did the work but no one was open on a Sunday so I don't know which codes cleared or what new codes have come up.
I would sure appreciate some help before I take it to a mechanic and spend a ton to get it resolved. Any ideas?
Thanks in advance!
Old Sep 20, 2015 | 07:00 PM
cbakker's Avatar
cbakker
Addressing the easy codes doesn't get you all the way. Any misfire codes? What other codes are you getting? Pretty easy to burn up a still save-able motor within 1,000 miles with a bad coil pack.
Old Sep 21, 2015 | 07:53 AM
Brian Hughes
I haven't had any misfire codes at all. I think the only other code (and I can't remember the number) was "heated O2 sensor bank 1". I've looked at the positioning of the coil packs and there's no way I can do those with my terrible back.
Do you think an O2 sensor can cause a sluggish response to acceleration?
Old Sep 22, 2015 | 07:26 PM
cbakker's Avatar
cbakker
It could be a wiring harness issue to the O2 sensor. It could also just be a burned out O2 sensor, and be as easy as swapping it out. I have had both scenarios happen.
Suhaj213
1997 - 2003 F150
Jun 7, 2013 11:52 PM
Skandocious
18
Jul 8, 2007 04:46 PM
Skandocious
Jan 29, 2007 11:39 AM
monsterbaby
1983 - 2012 Ranger & B-Series
Sep 13, 2006 04:43 AM
96f150
Nov 19, 2000 05:30 AM
