View Full Version : 1999 - 2003 7.3L Power Stroke Diesel
- Trouble On The Road
- Looking for used AIS kit.
- 2018 6.7 sold, stock 1999 ready for a few mods!
- Idle problems
- Looking for 7.3 Exhaust options and don't want to lose that 7.3 sound
- Power Cuts Out - 99
- Stumble in overdrive 7.3 4r100
- ICP Sensor Help
- Severe tire cupping
- New guy needs help with his Ambulance
- Losing Coolant
- 7.3 oil usage problem
- "New to me" 7.3 - top things to check?
- Chevron Delo 400 XLE SAE 15w40?
- Tie Rod Ends & Ball Joints: Selection, Removal, Replacement, & Tools Required
- Door Linkage
- '01 F250 Fuel/Oil Pressure issue. Not sure which.
- Stumped. Engine started dumping a LOT of oil, white smoke, pulled over and turned engine off
- Work van bad battery or?
- ICP datalog inside, need new HPOP?
- PMF Traction Bars / Lift Blocks / Air Bag Tang Combo
- Replacement Headlights
- Tough to start “cold@ starts well when warm.
- UOA sample acquisition
- 2000 Excursion 2wd Rear ABS Line
- Truck won't turn over
- Diagnostic equipment
- The axle gear thread (3.55, 3.73, 4.10, 4.30, 4.56)
- Valve retainers and locks
- Recovering from oil cooler failure
