ICP Sensor Help
Old Nov 11, 2021 | 02:55 PM
jct377's Avatar
jct377
ICP Sensor Help
Hey All,
I recently experienced hard starting with my '99 Ford 7.3 F-350 CC LB SRW 4x4. Then it turned into a no-starting issue. I managed to determine the culprit after systematically troubleshooting, and replaced the ICP sensor with a replacement kit from NAPA. However, I now have a engine check light and my Auto Ingenuity scan tool is reading a fault with the sensor, it will not perform a engine parameter scan while running. I made sure to methodically swap out the wires individually when replacing the original pigtail wire connector, as it was coated in oil. Should I disconnect the batteries to reset computer? I would greatly appreciate any feedback.
Regards from South Florida
Old Nov 11, 2021 | 03:19 PM
HKusp's Avatar
HKusp
Try swapping it with either a new genuine Ford ICP or borrow a known good Ford one for testing purposes.
Old Nov 11, 2021 | 05:26 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Have you identified the DTC setting the engine light? I assume it is ICP or pressure related, but would be wise to know for sure.
As mentioned above, only Motorcraft or International sensors for the 7.3L PSD.
Old Nov 12, 2021 | 11:52 PM
jct377's Avatar
jct377
No Dice! Went to the dealership and forked over double the cost of the NAPA ICP senor which I had just bought, and replaced it with the OEM sensor to the same result. The service engine light, triggered by the ICP sensor according to my scanner, is still on. I'm not sure if any internal damage could result by driving it in its current condition, so my truck will continue to stay parked until this is resolved. Has anyone else encountered this scenario?
Old Nov 13, 2021 | 06:06 AM
RacinJasonWV's Avatar
RacinJasonWV
What are your ICP values when running?
The ICP (pressure) is controlled by the IPR (regulator) solenoid. Confirm the small tin nut is still on the IPR. Inspect its wiring. I’d also double check the ICP wiring, especially since you just changed the pigtail.
Old Nov 13, 2021 | 08:39 AM
udsuth78's Avatar
udsuth78
An ICP issue shouldn't cause a no start, the engine will run just fine without it. Not as efficiently as if the PCM had that data, but run she will. What code is reporting? I'm w/ Jason on double checking the wiring connections. If they're plain ol' crimp butt connector then for sure triple check, I've been bit more times than I can remember by those little guys. It's why I switched to using the non insulated ones so I can crimp, then solder, then heat shrink, double layer if possible.
Old Nov 14, 2021 | 01:51 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
X2 on checking to see if the tin nut is still snug on the IPR, see below.
It's OK to disconnect the ICP sensor, truck will start and run without it. Not gonna hurt anything.
What codes are you getting?
Also please say more about what's going wrong with the truck.
T. Banning
Sep 15, 2021 05:23 PM
StrokinIT2001
Oct 13, 2017 06:28 AM
RideDiesel88
Jan 28, 2015 07:30 PM
94WhiteF250
Apr 25, 2011 08:20 PM
marivera
1997 - 2003 F150
Jun 24, 2003 01:07 AM
