Severe tire cupping
Old Nov 11, 2021 | 10:01 AM
Paul_R7.3's Avatar
Paul_R7.3
Severe tire cupping
I'm looking for reasons my tires are cupping. The rear tires appear to be fine, the problem is up front. I'm running oversized tires and truck has had a leveling kit installed by the previous owner. He said he didn't lift the truck other than the leveling kit but it sure looks like it's been lifted to me, this block on the rear axle measures 4". I installed new shocks on the front but if the truck has been lifted 4" the shocks are too short.
Front end pics
The tires are 35x12.50 R18. The front end has been rebuilt a year ago, new ball joints, ect., and the alignment is good. Would dual shocks help?
Thanks for any help.
Old Nov 11, 2021 | 10:31 AM
z31freakify's Avatar
z31freakify
I've have never found the cure for cupping, I just rotate them crossed in an X the cupping usually dissapears before the fronts start to cupping again.
Old Nov 11, 2021 | 10:41 AM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Rotate at 5k and if you have large tread blocks siping seems to help.
Old Nov 11, 2021 | 11:30 AM
Paul_R7.3's Avatar
Paul_R7.3
I'll be honest and confess I've never rotated the tires. I hope the fix is just that simple, thanks guys!
Can anybody confirm whether not the truck is lifted from the picture?
Old Nov 11, 2021 | 06:20 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
I have a set of 35's on the Bronco and 37's on my military dead dinosaur burner and cupping only get worse once it starts. Cross fronts to the back every 3000-5000 at most and it will minimize the cupping.
The bigger the tire and more aggressive the tread the worse it is.
Old Nov 11, 2021 | 06:32 PM
Eaglescout94's Avatar
Eaglescout94
Rear looks stockish, the blocks look like a factory 4”, front is hard to hell. Stock only has 2 leaves, both full length only.
Old Nov 12, 2021 | 02:56 AM
FinnishStroker's Avatar
FinnishStroker
The bigger/aggressive the tire is,the more it needs to be rotated.
Including flipping in the wheel too.
Old Nov 12, 2021 | 05:59 AM
Paul_R7.3's Avatar
Paul_R7.3
Never heard of flipping in the wheel, what is that?
Old Nov 12, 2021 | 06:31 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Proper inflation must be checked regularly. A rotation schedule must be adhered to including side to side.
Even then, sometimes a tire will have issues.
If you are having persistent issues despite your best efforts to avoid or mitigate them, try a different manufacturer or model of ture that has the same or identical usage goals in mind.
I run Cooper ST MAXX 265/75R16 towing heavy 90% of the time. I have ~50,000 miles on them now and on track for 65,000 or more miles. I perform the maintenance steps on them noted above regularly though.
Although, Cooper was just bought by Goodyear, so I may be in the market for a new manufacturer one day.
Good luck to you.
Old Nov 12, 2021 | 06:52 AM
FordTruckNoob's Avatar
FordTruckNoob
I think he means flipping the tire on the wheel so that what was the inside sidewall is now outside and vice versa.
What shocks did you replace with on the front? Regular shocks meant for the factory suspension will not work well because they are not valved for the added mass of oversized tires and, as you found out, too short for the lift needed to run the oversized tires.
Old Nov 12, 2021 | 09:24 AM
FinnishStroker
What Noob said,please excuse my Rally English!
Yes,If you installed too short shocks,it may accelerate the cupping effect.
Old Nov 12, 2021 | 09:47 AM
Boss73's Avatar
Boss73
The last time I had cupping issues on a set of 35" BFG's, I had a bad shock. Once I replaced the shocks and rotated tires to the back, they wore fine.
Old Nov 12, 2021 | 09:49 AM
uglypitbull's Avatar
uglypitbull
I know you said some of these were done.....but .....
check your shocks....check your sway links....check your ball joints.
I have stopped cupping on 3 different trucks because one or more of these were no bueno.
Old Nov 12, 2021 | 11:27 AM
Paul_R7.3's Avatar
Paul_R7.3
The shocks are Rancho RS7000's for front with 2.5" lift. They're supposed to be designed for off road so maybe they're too soft...? Looking at a set of Bilstein B8 5160 remote reservoir shocks and trying to convince myself I neeeed those. But that's probably going in the wrong direction
Old Nov 12, 2021 | 11:40 AM
FordTruckNoob
Hmm, RS7000s should be reasonable but the ones for a 2.5" higher suspension are meant to go on a truck with a leveling kit and not a bigger-tire lift kit I think. The valving may still be wrong for heavier tires. FWIW, I ran RS9000s on my 4" lift with 37" tires and I had cupping too, even with frequent rotation.
As for the remote reservoir Bilsteins, PMS is a respected tradition here and no one will give you flak for that.
