Looking for used AIS kit.
Old Nov 13, 2021 | 12:54 PM
Oldanvilyoungsmith's Avatar
Oldanvilyoungsmith
I'm trying to get my dad (who also has a 7.3) to upgrade from the stock rectangular filter setup to something better. I'm pointing him towards the AIS system, as it's quieter than the 6637, etc. (He doesn't want the truck to be louder) But still gives great filtration. But he (understandably) doesn't really wanna spend $400 plus for a new setup.
So if anyone has replaced their AIS setup, and wants to sell it. Let me know.
I'm also gonna call some local scrapyards next week and see if they have any.
Thanks all.
Old Nov 13, 2021 | 01:04 PM
WNYPSDguy's Avatar
WNYPSDguy
Thanks all.
$310 on rock auto right now. Looks under your year ford “air intake kit”
$282 at Varsity Ford
299 at Oreillys if you have them around.
Old Nov 13, 2021 | 01:08 PM
Oldanvilyoungsmith
Thank ya, hadn't looked there yet. Found a setup on a different website for $430.
I'm hoping we can find a used one for cheap, but we may just go that route.
Old Nov 13, 2021 | 01:46 PM
RacinJasonWV's Avatar
RacinJasonWV
I love the AIS. Great filtration and quiet too. Flows “well enough” with stock injectors and my T4 turbo.
I ended up getting mine from either Amazon or Summit Racing. Both were about the same price ~$300. Good luck on your search. Your dad will like the new intake.
Old Nov 13, 2021 | 02:04 PM
ESwift's Avatar
ESwift
CNCFAB
Amazon.
Right now it is at $276 from one of the sellers, other sellera are at $400+ as well. So look at the different sellers under the amazon listing. They fluctuate around, I had gotten a new one from Amazon for $230 back in June.
Amazon ais link
Old Nov 13, 2021 | 02:08 PM
ESwift's Avatar
ESwift
CNCFAB
Unless the factory box is cracked or not sealing tight, there isnt really any need for him to spend money on an intake, unless he is pushing a lot more then stock power.
Using quality filters is in reality going to filter fine and flow plenty for a tuned truck with a stock or modified stock turbo...
Old Nov 13, 2021 | 04:34 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
On the 6637 type side your battery maintenance is also easier as well. Yes it dose create a touch more noise but I like to hear the turbo breath.
Did I already say easer maintenance???
Old Nov 13, 2021 | 08:07 PM
arto_wa's Avatar
arto_wa
I managed to buy a used AIS setup from a fellow member here few years ago in order to replace the cracked factory filter box in my E99 F350 7.3 PS, but think it's well worth $300 if you are unable to find used one!
Have not really noticed any increased noise that I could tell.
The truck is all stock, except 4" exhaust & new bellow up pipes.
Old Nov 13, 2021 | 11:30 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Yes, you already did say easier maintenance... but how do you figure that battery maintenance is any easier with the 6637 type than with the AIS system that the OP seeks?
Taking another look at the photo that arto_wa supplied of his AIS installation... with the battery caps fully exposed and directly accessible...
And comparing the above photo with any given 6637 type installation in a 99-03, a random variety of which are are shown below...
... what we find is that the 6637 type of air filter installation in and of itself has no bearing on easing battery maintenance, which is impeded by a battery cover that requires the removal of both positive and negative battery leads first in order to remove the cover next in order to finally access the vent caps in order to check and maintain the battery in all the photos of 6637 installs above, EXCEPT for the photo of the AIS intalI, where there is no battery cover in the way.
Additional photos of various and random AIS installs bear this out, where no battery cover is included, required, nor necessary to re-utilize, with the AIS system...
As can be seen in each of the various AIS installs shown above, the battery is fully accessible, and the battery caps can be directly accessed and removed quickly for checking levels in each cell, measuring specific gravity with a hydrometer, and refilling with distilled water as needed, without removing any cables or battery cover.
UNLESS, one happens to encounter an AIS installation like mine shown in the photo below, where despite the OEM battery cover not being needed or a part of the AIS... I re-installed the old OEM cover over the battery anyway... because I don't bother with battery maintenance, and haven't fussed with checking or refilling water in batteries for more than a decade, and have no plans to. Ever. Since I don't give rat's amp what the electrolyte level in my batteries is, why should I even have to look at them?
However, my installation below is the exception, not the rule. In every other AIS install I have seen, there is no battery cover in the way of maintenance., which to my mind means that the 6637 can't be any easier than the AIS is as far as battery maintenance is concerned.
For anyone who believes in the importance of maintaining the electrolyte level in batteries (I don't, and couldn't be bothered with the hassle), then it is not recommended nor necessary to cover up the battery with the AIS, as I have done below:
Old Mar 20, 2022 | 01:09 PM
marksman76's Avatar
marksman76
Could not see where to start new post, that being said:
I purchased Motorcraft AIS kit but have not installed it yet.
Today my grill is off and I was going to do ZOODAD mod.
But is it really necessary or beneficial with the Motorcraft AIS kit?
If so should I do the front mod as seen on this forum in the past?
Or the secret sideways Zoodad mod?
Thank you all as always!!
Old Mar 20, 2022 | 01:15 PM
RacinJasonWV
Without a doubt I prefer the “secret” version Y2KW57 told us about in this thread. Secret Zoodad
This goes directly behind the grill and is completely hidden protecting from water etc but also utilizes the high pressure zone to force feed some air.
If you decide to not install the AIS let me know. I know a guy looking for one.
edit: “Post New Thread” is at the top of the forum. Scroll all the way up if on a phone.
Old Mar 20, 2022 | 01:27 PM
marksman76's Avatar
marksman76
RacinJasonWV
Should I do it EXACTLY like you depicted in 2018?
Thank you
Old Mar 20, 2022 | 01:32 PM
RacinJasonWV
Originally Posted by marksman76
RacinJasonWV
Thank you
If doing over I may try to enlarge the opening dimensions just a bit. Always wanting just a little more aren’t we?
Old Mar 20, 2022 | 02:06 PM
Shovelheadrob's Avatar
Shovelheadrob
What perfect timing fir a thread resurrection, my AIS has arrived & will be getting fitted in the coming weeks when time allows. Complete with zoodad mod!
Old Mar 20, 2022 | 02:08 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
If going bigger with the Secret ZooDad hole in the hidden rib of the rad support, the only caution I would have is to be mindful of how the truck behaves when turning down from a steeply crowned road immediately up into a steeply inclined driveway.
The body twist that occurs from each front tire traversing dissimilar planes will radiate through the radiator support, and too large of a hole in the vertical supporting rib could cause the fiber reinforced plastic structure to crack.
Ford likely found the right balance between opening up inhalation access while maintaining structural integrity in a dynamic on road / off road frame and body twist ditch environment.
