- Alcohol carb
- 4180 vacuum lines
- throttle body spacers
- Adj. fuel pressure reg. ??
- CFM for a 87 460 used for working
- Autolite 4100 or Edelbrock?
- primary jets not spraying fuel
- 4180 power valve vacuum hole
- carb spacer changed = no idle
- hesitation, found and repaired
- Carb and intake manifold questions
- accelerator pump not working
- Throttle position switch
- 1407 carb flooding on 400
- 1/4'' of fuel sittin under carb in manifold?
- Taurus fuel problems
- good source for fuel tanks, and a ? will bronco fuel tanks work on a pickup?
- Edelbrocks thunder series carbetuors
- fuel pressure problem...
- 4v intake manifold
- 2100 won't idle
- Is PVC pipe resistant to gasoline?
- How do you get varnish out of a plastic fuel tank?
- 4180 mixture screws?
- manual choke stick
- Lucas Oil Products
- Fuel Lines
- Leaking Gas tank!
- Octain
- Best steep angle carb?
