- Replace both fuel pumps, now truck will not stay running.
- small block carb recomendations?
- Ford EFI Broken plastic fuel line connector
- Edelbrock and Carter: are they the same carb?
- Need some Bronco II help! Was running rough, now not starting?
- Dual fuel pump
- 1bbl carter carb, floods at idle.
- engine dies when in gear
- Choke & High Idle
- motor idling fast then slow
- Holley 2300 ID
- Cleaning upper plenum
- Edelbrock/Holley Carb????
- Homemade Mechanical Secondaries?
- 302 EFI, MAF, & Firing Order
- EFI Problems, Need HELP!!!!
- Follow-up fuel guage question
- What carb do I have??????
- Out of Fuel with fuel still in the tank, HELP !!
- Liquid Soap/Shampoo in gas tank
- fuel system too lean
- '94 Ranger Codes 172,176
- Replacing carb - Right size CFM?
- electric choke dieing
- How do I reattach choke. 1bbl Carter, 1985 300 C.I.
- Gas Mileage??
- Dead Fuel Guage
- Intank pumps q's?
- Pre-tuning before installation?
- Which Carb Should I Buy?
