- Idle mixture setting on a Holly 2 barrel
- Truck looses power while driving
- 1979 f150 back fireing please help
- Will this Holley work?
- EFI Conversion
- more cfm from 850
- 4-Barrel Problems
- variable venturi- good theory, but executed badly?
- mechanical fuel injection
- EFI engine no start, suspect fuel problem
- Fuel pressure DANGEROUSLY high
- Fuel Pump Pressure?
- fuel problem
- having problems w/ my 1966 F100
- What size is the rubber tubing on my '76 F-250 fuel lines?
- Holley 4160 how to adjust
- Fuel problem
- Do I use my Ford Racing 19# Injectors?
- Would leaking fuel line cause truck to quit randomly?
- ease of rebuild on motorcraft carb?
- proper torque for holley 750
- installing 19# injectors
- need 2 brrl carb recommendations
- Throttle Plate
- new street avenger: idle to high?
- 2100: 1.08 or 1.33 on a 460 for maximum grunt?
- Commander 950 Pro
- New Carb. New issues
- 88 Ranger carb help/ID
- Hard Starting 460 Only When Cold
