Taurus fuel problems
Old Mar 17, 2004 | 10:09 AM
Tommy Shadrick's Avatar
Tommy Shadrick
1990 taurus 3.0
90 taurus runs great sitting, no pick up -sluggish on road until traveling speed. fuel injection?? all replys welcome
Old Mar 18, 2004 | 09:50 AM
Tommy Shadrick
1990 taurus 3.0
my problem started with bad water pump.since then,have replaced -pump,head gasket,plugs/wires,90% engine sensors. need second opinion.please tommy
Old Mar 18, 2004 | 11:54 AM
EPNCSU2006's Avatar
EPNCSU2006
Have you pulled codes?
Old Mar 18, 2004 | 12:08 PM
Tommy Shadrick
yes....I have pulled codes have gotten multipule...Cant get brain to erase even though I chaged out some sensors that was indicated as a problem....Original code still comes up.Map sensor out of range ect ect.........Thanks.
Old Mar 18, 2004 | 01:28 PM
EPNCSU2006's Avatar
EPNCSU2006
Did you test the sensors and wiring? If the codes are still there, then there is still a problem. How's the vacuum line on the MAP sensor, is it good? Sometimes codes can come up for sensors being out of range where something is causing them to be out of range, and a new sensor is not going to fix the problem.
