Throttle position switch
Old Mar 17, 2004 | 07:37 PM
Bullmax's Avatar
Bullmax
I have just replaced my tps switch and am wondering if there is anything i should have done prior to installing the switch other than just putting the new one in. I had an engine scan telling the tps was bad. I put the new one in and dont notice any difference. The engine light is still on, the front end shakes when trying to switch into od.
Old Mar 18, 2004 | 12:15 AM
c96drumm's Avatar
c96drumm
Welcome to FTE!
Did you disconnect the battery when changing the throttle position sensor? Disconnecting the battery will clear old trouble codes and reset the check engine light. Also something like a bad wire between the sensor and computer could cause a TPS code even if the TPS is good.
It would be helpful if you supply additional info, such as year,model, engine, mileage.
Good luck!
Old Apr 5, 2004 | 07:34 PM
Bullmax's Avatar
Bullmax
I disconnected the battery after I installed and drove it. It is a 98 windstar. The engine light stayed off for about an hour but now its back on.
PaysonPSD
96
May 18, 2023 10:17 PM
tjc transport
Modular V8 (4.6L, 5.4L)
May 29, 2016 08:46 AM
DSN46
Nov 20, 2013 11:25 PM
V8EXPLR
Oct 14, 2002 11:11 PM
eakanator
Jun 4, 2002 07:03 AM
