2001 expedition lock problem
Old Feb 5, 2013 | 01:03 PM
Shelby Forest Click's Avatar
Shelby Forest Click
hey im new to the forum. I have a 2001 expedition xlt.and i have a problem with my driver door lock. It unlocks and locks fine, but when i close my door when its unlocked the lock falls to the locked position. what could cause this.. any info would be great Thank You!!
Old Feb 5, 2013 | 01:56 PM
alloro's Avatar
alloro
A worn latch mechanism.
Old Feb 5, 2013 | 02:00 PM
Shelby Forest Click
what part would i need to get? and it also falls sometimes when i use the door handle
Old Feb 5, 2013 | 02:55 PM
alloro's Avatar
alloro
The L-a-t-c-h M-e-c-h-a-n-i-s-m
Old Feb 5, 2013 | 04:33 PM
r2millers's Avatar
r2millers
Shelby,
You have a built in "thermistor" or a protection device that doesn't allow the switching mechanism to burn up or start a fire if someone, usually a child, holds the lock button down for extended times. This unit is heat sensitive and will start to show signs of failing first in warmer temps.
If it's really cool out, they have a tendency to still operate once in a while.
If that's happening to you, that's a good place to start.
Old Feb 8, 2013 | 04:39 PM
r2millers's Avatar
r2millers
Originally Posted by r2millers
Shelby,
Shelby,
Just found this link in the F-250 super duty forum. It better explains what I mention above.
https://www.ford-trucks.com/forums/4...cks-fixed.html
Hope it helps.
Old Feb 12, 2013 | 05:23 PM
pappylonnie's Avatar
pappylonnie
Pappylonnie
2000 Expedition, A/C stoped working.
215,600 miles
Was told the it is called the black death.
Said the lines on the A/C system get cloged over the years
and need to be replaced.
By a qualified ford mec.
Any ideas?
Old Feb 12, 2013 | 05:47 PM
lv2race's Avatar
lv2race
215,600 miles
Any ideas?
Yeah,
Delete your question and start your own thread......................
Old Feb 13, 2013 | 09:38 AM
r2millers's Avatar
r2millers
215,600 miles
Any ideas?
Pappy, see you are new and to lv2 race's point, start your own thread for others to see, listing problem under "title."
Ck that your a/c clutch engages, your system isn't leaking and low with freon, knowing you have a low pressure sensor to protect it from running if low.
It could be simple fixes once checked if not a bad compressor, etc.
Old Feb 14, 2013 | 09:43 AM
2trux's Avatar
2trux
215,600 miles
Any ideas?
It would be interesting to know what the lines get clogged with as this is a closed system, and the lines are fairly large.
cworley250sd
Jul 10, 2013 10:03 AM
Powervoc
1997 - 2003 F150
Jun 24, 2010 07:58 AM
glk
Jun 14, 2004 02:51 PM
