Melling LPOP Install
Old Dec 22, 2020 | 04:13 PM
  #106
queen of spades's Avatar
queen of spades
Going to be doing this soon. Anything else I should consider doing while I'm in this deep?
Old Dec 22, 2020 | 04:16 PM
  #107
Flounder_Pounder's Avatar
Flounder_Pounder
6th Gear
Really easy to replace the CPS or lower radiator hose. Might put a coat of paint on it, rust pretty quick, I've spayed mine with rust preventative
Old Jan 6, 2021 | 06:46 PM
  #108
RustedNuts's Avatar
RustedNuts
First off, great write-up I believe I am in the same boat.
Question on initial symptoms though.
Did you by chance ever throw a check engine light while pulling a heavy load prior to replacing your LPOP? Consistently I will be on the highway and if I have a large hill the CEL will turn on and if I have fairly flat road the light will turn off after about 10-20 mins.
Thanks!
Old Jan 7, 2021 | 02:26 PM
  #109
duck fan's Avatar
duck fan
Because racetruck
Thanks!
No other symptoms besides the cold start issues.
Old Jan 7, 2021 | 02:53 PM
  #110
Brian Hanks's Avatar
Brian Hanks
Thanks!
did you check for codes? You running tunes?
Old Jan 8, 2021 | 09:57 AM
  #111
RustedNuts's Avatar
RustedNuts
Hi Brian I sent you a private message regarding the CEL since its probably not related to this thread. But just in case anyone is reading and has any other insight I do have a 50hp tune and the codes I threw were
P1211- Injector Control Pressure Higher/Lower Than Desired
P0541- Intake Air Heater Circuit Low
P0640- Intake Air Heater Control Circuit
Feel free to message me back or I might start a new thread, again, new here and still learning how to learn on here.
Thanks in Advance!
Old Aug 21, 2023 | 01:03 AM
  #112
furiousbob's Avatar
furiousbob
4wd Low
Sorry to revive an old thread but just wanted to thank you guys for this!
I've had my 1995 7.3 for 2 years now and it's always had that hard starting issue. I replaced countless sensors and seals. Decided to throw a Melling LPOP at it before investigating the HPOP further. Original LPOP looked fine as did the front cover mating surface with the exception of lots of sludge on the outside of the front seal. I'm guessing the front seal failed at some point but the oil leak wasn't obvious enough for me.
Just an FYI, someone does make a repair kit for those of you with damaged front covers. I have a cherry picker but there's no way in heck I was pulling that motor without a forklift IF my front cover was damaged. Link to the repair kit here if anyone needs it. Kinda pricey but I was contemplating making it myself out of some bronze on my vertical mill. Glad I didn't have to do any of that.
I rented most of the tools from O'Reilly's. Made my own flexplate hold down out of some scrap flat bar. My 3 foot torque wrench came in real handy for tightening down that crankshaft nut.
In any case, she starts up great now! Thanks again guys!
Old Aug 21, 2023 | 09:52 AM
  #113
knottyrope's Avatar
knottyrope
my 95 had a leak on the oil pump also, sometimes it would take 10 secs of cranking and oil gauge would move
thought i had a cracked pick up tube
when my Harmonic balancer failed, i went for new pump since it was leaking
startups are more consistent now even after sitting for two weeks
oil pump seal failure allows air in over time when sitting
90Ford73
Modular V10 (6.8l)
Jun 2, 2023 12:23 AM
87oldtimer
Oct 12, 2019 07:58 PM
bmwcarl
Jul 6, 2015 05:25 PM
vtwinbarblaster
1997 - 2003 F150
May 17, 2009 05:59 PM
krankshaft
Aerostar
13
Jan 15, 2005 10:16 PM
