Diag Help Needed for Danny(Mongo75)
Old Sep 2, 2010 | 03:15 PM
  #106
strokin'_tatsch's Avatar
strokin'_tatsch
Whats the word Danny? It only takes a couple hours to pull an oil cooler and a set of heads off an engine.
Old Sep 2, 2010 | 05:10 PM
  #107
Izzy351's Avatar
Izzy351
Originally Posted by Bonanza35
Joe, how do you tow heavy loads w/that ported ats housing. I am thinking on going with that on my stock turbo with ww. I tow a toy hauler. Thanks Chet I am thinking about egt's that why I want the 1.15 ported housing, is that what you have?
WW + ATS is too much, IMHO. I went with the stock wheel & ATS and it's a very nice combo. Lots of boost, no surge, and decent whistle. The 1.15 housing you're referring to is for the exhaust side of the van turbo. The ATS ported housing is on the intake side...
Old Sep 2, 2010 | 06:38 PM
  #108
mongo75's Avatar
mongo75
Travis, I had to leave off at pulling the engine and hen puling VC's and other small stuff. Between the damn base hobby shop only beng open Fri-Tues, and me doing my CDL class at the same time, I a mvery time limited. I will HOPEFULLY tear it apart tomorrow and have it tot he machine shop. Did you see my other post about how the oil cooler gasket looked?
Old Sep 2, 2010 | 08:45 PM
  #109
USAF CCM's Avatar
USAF CCM
I have Izzy's same setup.....tows my 7,000 31 ft TT with NO Problems. Gotta love those DP tow tunes!
Old Sep 3, 2010 | 02:58 AM
  #110
ron's power stroke's Avatar
ron's power stroke
keep an eye on ebay Danny..this set expired 8/28...just a little too late for you...i got my studs on there early this summer... they go for 400 quite often..
ARP Headstuds 7.3L Powerstroke Diesel: eBay Motors (item 220658158523 end time Aug-28-10 20:32:39 PDT)
Old Sep 3, 2010 | 03:04 PM
  #111
strokin'_tatsch
I did not see that post on the cooler gasket. Where was it? I will go look for it. I thought a cooler gasket would cause oil in coolant, not the other way around, but it might be possible to go the other way.
Old Sep 4, 2010 | 11:12 AM
  #112
mongo75's Avatar
mongo75
DAMN YOU RON- you cost me money! I just read your post before I pulled the trigger on a set of 910's and head BOLTS ($90 each from Summit). SO I figured, what the hell, I'll take ONE LAST LOOK at ePay. Lo and behold, I found one set of ARP's for $399 plus Ca sales tax. So that cost me $435. SO I figure Ron my friend, you owe me $435 minus $90 equals $345. I'll take check, money order or paypal!
Old Sep 6, 2010 | 12:50 AM
  #113
Bonanza35's Avatar
Bonanza35
Thanks Joe, I didn't reallize the ported housing was intake. I was just looking at my freinds and his turbo exhaust side from banks is much larger then my stock one with lower egt's. I also am looking for a 38 ft toyhauler to tow so I want to keep egt's low as possible.
Old Sep 7, 2010 | 03:33 PM
  #114
strokin'_tatsch
Danny, using the ARP studs it's a good idea to torque the heads down then let them sit for a day or 2 then retorque them again. Either that or you can do a hot retorque on them once the engine is back in the truck and running. Easier to let it sit for a day or 2 on the stand to settle then retorque. You will probably get a little bit more on a couple studs.. Good luck with it brother.
Old Sep 8, 2010 | 12:48 AM
  #115
mongo75's Avatar
mongo75
Took it to the machine shop today, and the guy said the crank was w/i specs, toward the high side, but definitely in. The cylinders look good too, so hopefully it was just the bearings that took the beating and I can slap it all back together after a fresh hone.
Old Sep 8, 2010 | 01:22 AM
  #116
Stangrcr1's Avatar
Stangrcr1
Whose thread is this?
Old Sep 8, 2010 | 03:39 PM
  #117
strokin'_tatsch
So they didn't find any cracks then when they magnaflux'd it??? Thats great news!!
Old Sep 8, 2010 | 05:07 PM
  #118
clem1226's Avatar
clem1226
mongo75's, Clay started it for him.
Old Sep 8, 2010 | 10:31 PM
  #119
mongo75's Avatar
mongo75
Travis, no they didn't mag it yet, or at least I haven't heard from them yet, I'll call tomorrow and see what they have to say. Now Im just trying to get all the darn part coming in as fast as I can.
Old Sep 9, 2010 | 02:01 PM
  #120
mongo75's Avatar
mongo75
Just got the call from the machine shop- DIAGNOSIS- cracked block! they said it was cracked from the #2/ main bearing to the cam bearng up the cylinder wall. WTF!?!?! What would cause this to happen? I though these blocks were stout! uuuggghhhh, now igotta spend MORE money I don't have.....
