How to sit level
Old Apr 21, 2010 | 01:13 PM
skyfox10's Avatar
skyfox10
Question How to sit level
Looking for opinions on how to get a truck to sit level or just under level.
I've seen guys use f250 or f350 springs to get 1.5"-2" lift, but I've also seen there it can be tough to get to get to the castle nut or whatever afterward.
I guess what I'm hoping for is. How did you do it? how did it ride compared to stock after you made the change?
Thanks.
Old Apr 21, 2010 | 04:11 PM
fordman1090's Avatar
fordman1090
I never had a problem with getting to the castle nut.
They lift the front an 1in or so. Not quite level but really close. The ride is alot rougher. But it helps get rid of sway. I also think a good pair of shocks would help that greatly.
Old Apr 21, 2010 | 06:28 PM
BCHauler's Avatar
BCHauler
I found the swap to be very easy. Hardest part is some alignment shops claim they can't align it if the coil touches the nut but they are wrong. I personally don't find the ride to be rougher, but is is definately stronger. I got about 1 3/4" of lift.
Old Apr 21, 2010 | 07:14 PM
skyfox10's Avatar
skyfox10
what did you guys put in, 250 or 350 springs?
Also, comments on 2" leveling springs are also welcome.
Old Apr 21, 2010 | 09:59 PM
nashaj's Avatar
nashaj
I just did this mod on Monday. Check out my post on it. I used moog 844 springs. Its sits close to level. A little lower in the front then in the back, but you cant tell unless break out the tape measure. The spring doesnt touch the castle nut on either side, there's about a 1/4in clearance.
Old Apr 21, 2010 | 10:09 PM
fishforlife2007's Avatar
fishforlife2007
i put the rough country leveling springs on my truck, and while i did it i put all new shocks on the truck (6!). yes the ride is a little bit rougher than the worn out original springs, but i dont mind it at all. the whole swap took me about 2 hours shocks and all. parts wise it was about a $370 upgrade. that included the rough country leveling springs, six new rough country nitro series shocks, and the new camber bushings. since doing the level i love the way the truck looks and i get comments all the time about its stance.
Old Apr 21, 2010 | 10:28 PM
cadillacmob's Avatar
cadillacmob
Thanks.
I been wantin to level my truck because i want to run 33's . I found this new kit on ebay. !opinions would be good! I was going to make my own post but i figure i would post it up for you .
FORD F150 F-150 1981-1996 4WD 2" LEVELING LIFT KIT FB2A : eBay Motors (item 110513842804 end time Apr-29-10 12:22:15 PDT)
Old Apr 21, 2010 | 11:08 PM
SaikotikGunman's Avatar
SaikotikGunman
I need springs and/or shocks anyway, so I'm thinking about going this route...
Old Apr 22, 2010 | 12:21 AM
skyfox10's Avatar
skyfox10
I did the same mod on my last truck with stainless steal washers (got them at cost). I stacked them on the stud under the spring cup. If you want to go this route, you can do it for cheaper with washers. Otherwise, I'd go for springs. If you want to save money, I figure you could get used springs at a junk yard.
Old Apr 22, 2010 | 12:43 AM
BCHauler's Avatar
BCHauler
I used the moog 844 springs.
Old Apr 22, 2010 | 12:55 AM
skyfox10's Avatar
skyfox10
can you get Moog stuff at most auto supply places, or are there certain places to look?
Old Apr 22, 2010 | 01:10 AM
nashaj's Avatar
nashaj
Advance Auto, Checkers/O'reilly. You can order them from jegs or summit for about $82 shipped.
Old Apr 22, 2010 | 07:46 AM
skyfox10's Avatar
skyfox10
$82 each or $82/pair?
Old Apr 22, 2010 | 08:12 AM
SaikotikGunman
RockAuto has them by the pair for $78.79 before shipping.
Tempting, but I don't feel like having to pay for an alignment after spending time and money doing springs and shocks.
Old Apr 22, 2010 | 09:10 AM
skyfox10's Avatar
skyfox10
I guess the best thing would be to wait till you need an alignment, the get the springs.
