How to sit level
Old Jun 5, 2011 | 09:45 PM
  #196
xc4jokestomper's Avatar
xc4jokestomper
Ive only got a 302 in mine. Will i need special bushings for the camber?
Old Jun 6, 2011 | 11:53 PM
  #197
fstbck1970's Avatar
fstbck1970
not sure. I don't think 302's are too much bigger. Ill try to remember to take a picture of them tomorrow so you can compare them with yours.
Old Jun 7, 2011 | 11:43 PM
  #198
TexasGuy001's Avatar
TexasGuy001
It doesn't matter what engine you have. You will need to get the alignment done after lifting the front. You will also need the camber bushings, unless someone already had them changed out.
Old Jun 7, 2011 | 11:48 PM
  #199
Jason Lewis's Avatar
Jason Lewis
[QUOTE=TexasGuy001;10434771]It doesn't matter what engine you have. You will need to get the alignment done after lifting the front. You will also need the camber bushings,
Same is true if your lower !
Old Jun 8, 2011 | 12:54 AM
  #200
Midnite1987's Avatar
Midnite1987
i think i have decided to go with the 844s springs for the front, but for the rear will stock f250 rear springs fit in the hangers? seems to me i read something about them being too wide....if so would that give a f150 the stance of a f250? if they will fit pnp here i come lol used 250 springs should still be better then 150springs i would think
Old Jun 8, 2011 | 07:37 AM
  #201
xc4jokestomper
are thr camber bushings ill need just ur regular bushings or will i need a different set?
Old Jun 8, 2011 | 09:31 AM
  #202
hav24wheel's Avatar
hav24wheel
Don't need to worry about buying camber bushings, do what you have to to the springs, and axle pivot/radius arm bushings and take it in to get aligned. A good shop will have the propler alinment shims/bushings on hand for you.
Old Jun 11, 2011 | 08:00 PM
  #203
BIGskinny's Avatar
BIGskinny
im lookin at these shocks for the front end...Monroe Sensa-Trac Load Adjustable Shock Absorber..does any body think itll pick the front end up any or help with body roll?
Old Jun 11, 2011 | 11:35 PM
  #204
fstbck1970's Avatar
fstbck1970
Oh ok well thats how the mechanic explained it to me....
Old Jun 12, 2011 | 06:31 AM
  #205
TexasGuy001
I would never use any type of load carrying shock. This includes air shocks and those you are talking about.
ct diesel
6.7L Power Stroke Diesel
Dec 21, 2013 12:40 AM
AKFORD4x4
Jul 19, 2011 04:35 PM
66 BADBOY
Dec 16, 2008 02:52 PM
viperbluelx
Jul 5, 2007 11:08 PM
brooknbrown
2004 - 2008 F150
May 7, 2005 05:28 AM
