How to sit level
Old May 4, 2010 | 09:38 PM
  #106
cadillacmob's Avatar
cadillacmob
Originally Posted by skyfox10
I don't think there there is a huge difference in add-a-leaf springs. If the price is right, I'd say go for it.
or i was thinkin a one or two inch lift block for rear leafs
Old May 4, 2010 | 09:47 PM
  #107
skyfox10's Avatar
skyfox10
I've known some guys to add a leaf and remove the factory block. This makes me think that the leaf is a better route, but I couldn't tell you why.
  #108
skyfox10's Avatar
skyfox10
Originally Posted by SaikotikGunman
Didn't have a tall socket handy that fit them.
I'd say that's a pretty darn good reason
Old May 4, 2010 | 09:56 PM
  #109
cadillacmob
ya it makes me wonder . i really dont know.
My friend has a 01 ram with 13 inches of lift. it has some lift blocks in back i think 3 inches or somethin. i dunno how his were put in . he had a local off road shop put in the lift
Old May 5, 2010 | 08:23 AM
  #110
TexasGuy001's Avatar
TexasGuy001
Hey Skyfox, After seeing this picture, I would not alter your truck suspension at all. The stance is perfect.
Old May 5, 2010 | 09:20 AM
  #111
skyfox10's Avatar
skyfox10
I think it's a flattering pic. I mean, it does look good, but I have to park next to a dodge at work, and the stock dodges are so tall. I feel like I'm driving a mini.
Would this pic change your mind or are you sticking to it?
Old May 5, 2010 | 09:21 AM
  #112
Bob Gervais's Avatar
Bob Gervais
Both are good options, but it all depends on the goal. Add a leaves will lift and increase the spring's load capacity, but make the ride harsher. Blocks will lift, and since the spring is not changed at all, you'll still have the stock ride quality.
Also, the amount of lift an add a leaf gives is pretty unpredictable. Lots of factors involved, such as age and condition of the stock springs, what the spring rate was from the factory, etc.
caddilacmob, it sounds to me from reading your posts that you'd like to lift a little, and also add load capacity to the spring. In that case, I'd go with an add a leaf.
Old May 5, 2010 | 09:46 AM
  #113
TexasGuy001
I still wouldn't alter it. It is funny how sometimes the stance looks different depending on how its parked. Also if you back in some where the nose sits lower. Have you noticed that?
By the way, who cares about the Dodge at work? LOL...
Old May 5, 2010 | 09:58 AM
  #114
Bob Gervais
Dodge makes their trucks with higher ride heights so it's easier to get the trans out when it needs replacement every 20k miles. It also makes it easier to replace the rotted out rocker panels at 2 year intervals.
Old May 5, 2010 | 10:19 AM
  #115
skyfox10's Avatar
skyfox10
Backing in might actually be part of my problem. I back in 95% of the time, and at home, that means that it's pointing down hill. Parking on an incline looks great though.
I guess, I just don't like being the little guy. Really, I should be glad that I'm not in a dodge, regardless of ride height. Just this week, I found out that his motor is beginning to give a bit of a knocking.
You described this truck perfectly.
Old May 5, 2010 | 11:01 AM
  #116
BCHauler's Avatar
BCHauler
I think a truck should have a bit of a rake. It makes it look like it can perform like a truck.
Old May 5, 2010 | 02:44 PM
  #117
skyfox10's Avatar
skyfox10
Agreed. I don't really want to go totally level though, just a bit closer to to. I've had this truck almost 2 years and still haven't gotten around to putting the hitch on it.
Didn't you poot the Moog cc844's on your rig and have it come out level?
Old May 5, 2010 | 06:44 PM
  #118
cadillacmob
ya your correct , i would like to handel a little more . but its like you said the add a leafs are unpredictable so that makes me worry a little. cause i want the stance of the truck just right
Old May 5, 2010 | 09:35 PM
  #119
skyfox10's Avatar
skyfox10
maybe, get an add a leaf, and use or remove lift blocks to fine tune. That's probably the best way to fine tune the lift. (other than aiming high and adding cinder blocks to bring it down )
Old May 5, 2010 | 10:24 PM
  #120
Bob Gervais
I actually had to remove leaves from mine. The PO had put new springs on, and for some reason had 7-leaf springs installed. Granted, it handled a lot of weight without sagging too much, but the rear was about three inches higher than the front, even with the 844's installed. It also rode like someone welded the axle to the frame.
I took out two leaves per side, and got lucky. The stance is what I wanted, and it still handles a decent load. Wait, that sounded kinda dirty....
