Minnesota Chapter Join Chapter, Leader: fordpower88
Almost spring (march) B.S. thread
Old Mar 24, 2010 | 10:13 PM
  #856
fordpower88's Avatar
fordpower88
I cant say for sure but I believe so with some modification to your mounting brackets. I think your V10 coolers are even bigger than our stock 7.3 ones but the 6.0 makes two versions a 26 row and a 31 row both are excellant coolers.
Old Mar 24, 2010 | 10:17 PM
  #857
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
I wonder which one we have on the V10?
Old Mar 24, 2010 | 10:21 PM
  #858
fordpower88
I am not sure of the answer to your question there Steve. I would have to do a little research. I will see what I can find and get back to ya.
Old Mar 24, 2010 | 10:25 PM
  #859
sddesigns's Avatar
sddesigns
FTE Emeritus
I did know it was bigger than the 7.3, because I had mentioned I wanted to add a bigger trans cooler on and somebody made that comment. But is it the same as the 6.0 small or larger model?
Old Mar 24, 2010 | 10:28 PM
  #860
fordpower88
If I had to guess I would say it is the size of the smaller one or maybe a little smaller than that but bigger than the 7.3 one.
Old Mar 24, 2010 | 10:31 PM
  #861
Skattracker3's Avatar
Skattracker3
Watch it Steve, those 6.0 tranny coolers are getting to be a hot commodity around here.
Just wondering, If you only tow 4K about 4 miles why do you want a bigger one?
Old Mar 24, 2010 | 10:34 PM
  #862
sddesigns's Avatar
sddesigns
FTE Emeritus
I will be going to Vermont next year with the boat, and I always want any extra cooling available.
Old Mar 24, 2010 | 10:37 PM
  #863
fordpower88
Steve I did a quick search on partsguyed.com and the 6.0 cooler is about $100 more than the V10 one but it didnt mention size.
Lee if you find enough coolers you can bring them to a GTG and have a tailgate sale!! lol
Old Mar 24, 2010 | 10:38 PM
  #864
Skattracker3
Great Steve, makes a lot of sense, now I will want one too.
Old Mar 24, 2010 | 10:39 PM
  #865
sddesigns's Avatar
sddesigns
FTE Emeritus
You do yours first take lot's of pictures and then I'll do mine...lol
Old Mar 24, 2010 | 10:42 PM
  #866
fordpower88
Boy Lee if you come to the install party you will have all sorts of projects selling and installing 6.0 coolers!!
  #867
Skattracker3
Forgot to mention. I think I got that blank tidy blank lawn mower done. Pulled the engine out again, only took 20 minutes after all the practice. They wanted $50 for one coil & wire, so I switched the front to back and taped them all the way up. It runs almost perfect now, but still misses very seldom on the same cylinder as before. Can't be spark plug or coil, have no clue on what else. Valves were all lapped, head leveled and all new gaskets. I will run it the way it is, should be fine and has alot more power than befrore I started.
Old Mar 24, 2010 | 10:46 PM
  #868
Skattracker3
I will probably stick with what I have for now. According to the stock gauge have never seen it over 3/4, except once pulling 14A in Wyoming with 12% grades for 17 miles in low gear at 25mph. Pulled over a couple of times to let cool. Now with the scan gauge, I will have an actual temp to watch.
  #869
fordpower88
Glad to hear ya got it up and running again! Now all we need is some warmer weather to get the grass growing so you can test it out. How long does it take you to mow that 5 acres?
Old Mar 24, 2010 | 10:52 PM
  #870
Skattracker3
Usually about 2hrs 15 min avg. The best is 1hr 58min. I time myself.
The wife (Michelle) used to help me, be she did not like our hydro front engine rider Cub Cadet, especially after she used the zero turn. She kept saying I just want a walk behind, so,two years ago I went to an auction and bought her a 52" Toro commercial walk behind. Got a good deal.
With both we can mow in about 1 hr 35min, but have got it done in 1 hr 20min. She does not help me much anymore, we work different shifts, now she just grabs the zero turn and does it all or just part of it.
