First Time Noob post
Old Jun 2, 2013 | 08:53 AM
  #151
RWENUTS's Avatar
RWENUTS
They're an evil necessity! I like clean not oily too!! You could go custom with a braided hose.
Mooneyes Online Store - Specialty Equipment Manufacturer, Speed and Custom Parts for Motorcycles and Automobiles
Old Jun 2, 2013 | 02:56 PM
  #152
orangeford's Avatar
orangeford
You might be able to use an f350 dual diaphragm booster and master cylinder. It is a smaller diameter and might clear those valve covers.
Old Jun 2, 2013 | 10:05 PM
  #153
HardkaseDaddy's Avatar
HardkaseDaddy
Thank you for the feedback on the breathers RWENUTS, and for the suggestion on the mc orangeford. I'm still thinking of going without power brakes. I don't rerally trust the cam on this engine to produce enough vacuum. It's a comp cam with 290 duration, 110 degrees of lobe separation. There are hotter cams out there, but this one might give me problems if I am relying on vacuum for braking power. I would sure like to source a good threaded pushrod for the mastercylinder so I can tune the length of the mc pushrod. Yikes! I just want to make sure this truck will stop.
Another thread in the FTE site with some good information on brake boosters and master cylinders.
https://www.ford-trucks.com/forums/9...n-an-f250.html
Old Jun 27, 2013 | 03:02 PM
  #154
HardkaseDaddy
Switches
I made a little button cluster for a few of the add-ons a couple of weeks ago. I've been working a lot more the last few months so I have been neglecting the green goat for a while. I got these cool toggle switches on Ebay with led lights on the ends of them. Green is for Gas. Red is for Roll control. I left space for one more switch. What will go in the spare spot, I'm not really sure yet (push button start, auxilliary lights, nitrous ...)
Soo while I bent up some metal for the toggle switch panel, my son did his own modification of the cracked steering wheel. Gotta love it! He's a ford guy through and through.
Old Aug 17, 2013 | 12:17 PM
  #155
HardkaseDaddy
Update: The engine runs!!
I flashed up the engine in the old truck. It sounds loud and obnoxious. I love it.
I'm still trying to tune it so it will kind of idle. Tuning this motor with the radical cam it has in it is going to be a challenge for me.
Old Aug 17, 2013 | 12:39 PM
  #156
73 ford guy's Avatar
73 ford guy
You figure out the brakes? You should just install a hydroboost
Old Aug 21, 2013 | 12:06 AM
  #157
HardkaseDaddy
I think hydroboost is a good option. I have not gone and found the parts yet.
Old Aug 21, 2013 | 12:14 AM
  #158
HardkaseDaddy
Gremlins in the motor
Well the motor is pulling coolant into the oil somewhere. I've started to tear down the top end. I'm hoping it's a bad gasket. So far the only fault I have found is a leaking thermostat housing gasket. I went at it after I finished work last ngiht didn't get the intake manifold off yet I would like to examine the intake gaskets, and then remove the heads if necessary.
I have to say this setback is quite discouraging. I am keeping my fingers crossed that there are no cracks in the castings.
Old Aug 21, 2013 | 03:30 AM
  #159
keiths78f150's Avatar
keiths78f150
Hope it's not too serious. A setback like that is always discouraging!
Old Aug 21, 2013 | 09:29 AM
  #160
73 ford guy
If you go that route contact Duke point auto recycling just south of nanaimo. They carry all newer trucks. Get one from a 99 up superduty then ship it. I paid $75 for hydro boost,shipping is prob $25
Don't get a older crap car one. Get a newer style hydroboost.
Old Aug 21, 2013 | 10:42 AM
  #161
HardkaseDaddy
Thanks ford guy. I go to Nanaimo often. I'll check them out.
Old Sep 18, 2013 | 12:40 PM
  #162
HardkaseDaddy
I got the engine put back together. I took it apart and cleaned the mayonnaise out of it. When I tore open the engine the head bolts were torqued to 35 lbs. Water was crossing over the gasket surfaces and mixing in the sump.
Strange... I wonder if the guy I bought it from left the heads loose for a reason, or possibly he just forgot.
Anyway everything looks good for a start up this week. While I was waiting for a gasket kit to come in the mail I took the time to wire up an ignition box from Procomp Electronics. I have a few minor things to take care of, and work keeping me away from the shop for part of this week. I'll post pics later.
Old Oct 23, 2013 | 12:52 AM
  #163
HardkaseDaddy
Finally got it running last night. The (brand spanking new) HEI distributor had a tiny split ring washer stuck to the main shaft under the advance springs that was holding things up. Chalk this delay up to poor quality control at the Procomp dizzy factory I suppose. Anyway I tore out the dizzy, stripped it down to nothing, found the fault, rebuilt it, reinstalled it AND the engine is back to the land of the living.
Old Oct 23, 2013 | 12:08 PM
  #164
PHXCobra's Avatar
PHXCobra
Let's hear it run. Post a vid!
Old Oct 29, 2013 | 09:54 PM
  #165
HardkaseDaddy
OK
<iframe width="480" height="360" src="//www.youtube.com/embed/IOtdE8nFGUI" frameborder="0" allowfullscreen></iframe>
