Connecticut Chapter Join Chapter, Leader:
August B/S Thread
Old Aug 20, 2009 | 03:52 PM
  #511
gbroehl1's Avatar
gbroehl1
Afternoon Dave.
Old Aug 20, 2009 | 03:56 PM
  #512
Aerocell4x4's Avatar
Aerocell4x4
Diesel Van Enthusiast
Originally Posted by ArdWrknTrk
Good morning Rich and Brian!
I need to unload my truck. (got back late, was in an attic so I was wiped)
May head down to Stamford to check my P.O. box and scope some jobs in Greenwich.
Well if you didn't make it down today, then maybe we can meet for lunch tomorrow as I'm headding down to work early so I can stop in Norwalk at the Performance Specialties with the hopes that my stuff is in before I head off on vacation for a week.
Old Aug 20, 2009 | 03:57 PM
  #513
Aerocell4x4
Hi there Greg.
Old Aug 20, 2009 | 04:06 PM
  #514
Aerocell4x4
Originally Posted by spike552
awwww mannnn i gotta do an oil change today, iam just dragging.
I just installed a Qwik Valve oil drain valve on my engine.
I got the F-111N which has the hose nipple and the optional Corbin clamp to lock it closed.
I used a rubber teat for capping off vacuum connections just to keep the nipple clean, and it'll let me know if the valve leaks by as the nipple will fill up and I'll have a cap-full when I remove it.
Eyeballing the nipple extending off that valve, I suspect I'll rip out my steering gear before whatever can take out the drain valve. I suspect that's because of the Quigley 4x4 modifications.
The valve uses a fiber washer as a gasket.
Old Aug 20, 2009 | 04:14 PM
  #515
Aerocell4x4
Originally Posted by mox-ct
Dave,
Did you see this book? http://www.ringpinion.com/ProductDet...px?ProdID=6660 I ordered one and they sent me two, you want one? Also on the same website did you notice the downloads, technical help and calculators?
Rich:
I saw the advertisement for the book, thank you, yepper I'd enjoy reading it.
May I suggest that you just leave it in your truck for the next time we have a GTG.
I wasn't planning on buying a copy as I figured I'd have ordered the differential before the book ever arrived.
Yes, I have been reading their's and others tech info, thanks for the heads up.
Long ago when I was first researching tire upgrades for my van, I had stumbled upon a few Calculators, that's were I got the ratios from in my earlier posts.
Old Aug 20, 2009 | 04:27 PM
  #516
Aerocell4x4
As for differentials of interest to-date.
ARB wrote back today and said they only have a locker (RD36) for the front Dana 60, and nothing for a the rear Dana 70U on my van.
I haven't heard back from Richmond Gear about their Powertrax differentials for my 'unlisted application.'
Their No-Slip will fit up to a Dana 60 Front Axle.
Their Lock-Right will fit up to a Dana 70.
Old Aug 20, 2009 | 04:32 PM
  #517
mox-ct's Avatar
mox-ct
What, i can't hear you
This is lame, it won't let me use caps to simulate yelling...
Originally Posted by aerocell4x4
glad you had a good time.
I suppose you knew in advance that today would not be your annual hearing test courtesy of the company. :-x22
Old Aug 20, 2009 | 04:37 PM
  #518
Aerocell4x4
My new mousepad just arrived last night.
For those willing a peek Google B u s t y mousepads
Old Aug 20, 2009 | 05:04 PM
  #519
Aerocell4x4
The more I read about the Lock-Right it seems intended for pure off-highway use
Old Aug 20, 2009 | 06:01 PM
  #520
sglaine's Avatar
sglaine
Posting Legend
Good evening CT
Old Aug 20, 2009 | 06:03 PM
  #521
Aerocell4x4
Hi there Sean
Old Aug 20, 2009 | 07:15 PM
  #522
mox-ct's Avatar
mox-ct
Good evening guys.
Dave,
The statement "towing applications, and even United Nation vehicles in rugged terrain" sold me. But I still like the selectable locker, have you checked the elocker? or how about the OX locker? Of course the decision is yours, but I just wanted to through out these options.
Old Aug 20, 2009 | 07:32 PM
  #523
Aerocell4x4
Rich, yes I have been checking out the others.
Since I got the email back from ARB's "Sales Manager; Canada and Northeast USA" saying ARB didn't offer any lockers for the 70U, I Googled 70U locker and discovered that ARB lists them.
http://www.arbusa.com/uploads/PDF/ne...dvice/0-00.pdf
I am still confused as to what axle spline count I have, I don't know if the spline count changed over the years or if what I have read has been misinformed forum comments.
At this moment I'm leaning toward ARB's front and rear with Yukon ring & pinion should the fit.
I'm not ready to trouble Randy's Ring & Pinion with an email. That'll wait for when I get back from vacation and have another paycheck to put money where my mouth is.
I looking at another $1500 per axle in material for this mod.
Old Aug 20, 2009 | 07:36 PM
  #524
sglaine's Avatar
sglaine
Posting Legend
Any partys around
Old Aug 20, 2009 | 07:43 PM
  #525
Aerocell4x4
I came upon an interesting tidbit.
Supposedly all versions of the Dana 70 axle have the same cover.
Supposedly the Dana 60 & 70 axles are outwardly the same and thus take the same cover, again could be a misinformed post or typo.
ARB only shows their differential cover as fitting a Dana 50 & 60 but not a Dana 70.
