Hydroboost conversion done!
Old Sep 27, 2018 | 08:44 AM
  #196
Ruckin69's Avatar
Ruckin69
Originally Posted by Monstermiler
Try these
Make sure the one you get comes with Master Cylinder push rod.
https://www.rockauto.com/en/catalog/...e+booster,1884
Which one?
Old Sep 27, 2018 | 08:51 AM
  #197
Monstermiler's Avatar
Monstermiler
Trailering
My preference is the Motorcraft BRB-37
Old Sep 27, 2018 | 09:11 AM
  #198
Aaron-71's Avatar
Aaron-71
Originally Posted by F-250 restorer
I found these posts in my Hydro B. file. Aaron, ford used a Saginaw pump with dual returns on a 76 LTD. I have one.
I stand corrected. But that's 1 thing that may be difficult to find in any sort of decent condition.
Wonder if those dual return saginaws are still sold through the parts stores?
Old Sep 27, 2018 | 12:04 PM
  #199
F-250 restorer's Avatar
F-250 restorer
Hey, I'm sorry Aaron. I didn't mean to sound like I was calling you out, ha ha.
Old Sep 27, 2018 | 01:32 PM
  #200
Aaron-71's Avatar
Aaron-71
No apology needed - I didn't take it that way at all.
I thought I remembered someone mentioning a dual return Saginaw a long time ago, but also remember that they mentioned how difficult it was to source. Had no idea they came factory on some Ford vehicles... wish I woulda known that when I pulled a bunch of stuff off a 84 LTD! Coulda had me a nice rebuildable power steering unit if I knew it at the time.
Live and learn lol.
I like how you put together a very nice list of applicable vehicles with HB systems in them. We should keep that list going because I find this thread very hard to get anything concrete from... basically need to start a "Part 2" that does a better job of explaining and summarizing the nitty gritty.
Old Sep 28, 2018 | 05:52 AM
  #201
Ruckin69's Avatar
Ruckin69
https://shop.broncograveyard.com/Hyd...products/1200/
How about one of these? Pricey though.
Old Oct 1, 2018 | 04:30 PM
  #202
Ruckin69's Avatar
Ruckin69
Is this a correct hydroboost from a f450
Old Oct 1, 2018 | 04:34 PM
  #203
Aaron-71's Avatar
Aaron-71
Yes that's a hydroboost unit. And yes it will work.
By the looks of it, it needs a rebuild. It's very greasy and may have bad seals in it.
While you're at it, grab the entire assembly (Master Cylinder + Hydroboost) because it will be easier to retrofit both together rather than reusing your old master cylinder... and you'll have a clear M/C housing to boot!
Old Oct 1, 2018 | 04:46 PM
  #204
Monstermiler
Trailering
Grab the pedal assembly if you can. Especially the brake pedal. If you use your existing brake pedal and factory firewall location you will find the pushrod from the pedal is not straight. It needs to be straight. Some lower the hydraboost but the proper thing to do it raised the pushrod mount on the pedal. If you compare your pedal to the pedal from the F450 you will find the pushrod pin is 5/8-3/4" inch higher on the F-450 Pedal. To me raising the pin is the proper thing to do as it keeps the pedal ratio the same as the F450 has, also the pedal will sit higher.
Old Oct 3, 2018 | 10:14 AM
  #205
Ruckin69's Avatar
Ruckin69
For the F-450 s do you need a standard brake pedals if you have a standard or an auto if you have an auto for the swap? The guy who selling Parts says they are different.
Old Oct 3, 2018 | 10:27 AM
  #206
Monstermiler
Trailering
Yes the pedals are different between Automatic and Manual transmissions. Get the one that matches your current setup.
Old Oct 21, 2018 | 11:34 PM
  #207
Kuhndawg's Avatar
Kuhndawg
Here is a diagram if that helps
Originally Posted by rh1231979
Bueller? Bueller? Anyone?
I'd like to see this as well! Surely someone here has a diagram or pics of the plumbing between the hydroboost, steering pump and gearbox...
I know there are other threads about the HB conversion, but I'd like to see more/better pics and information.
Old Jan 8, 2019 | 07:03 AM
  #208
Ruckin69's Avatar
Ruckin69
Subscribed for a future project.
Old Jan 16, 2019 | 08:25 AM
  #209
TXTrailerdaddy's Avatar
TXTrailerdaddy
subscribing. About to start the project.
Old Jan 16, 2019 | 08:43 AM
  #210
ford390gashog's Avatar
ford390gashog
For reference you don't need a new pedal. You do need to remove the F450 hydroboost mounting plate and flip it 180 degrees and grind off the locating tab and remove all 4 of the studs. Once that is done everything lines up and you can use your stock bolts to attach the booster.
