Abs sensor hole: Lubes wheel or needle bearings?
Well, I am coming up on the time to do a needle bearing lube, and am wondering if I shoot some axle grease into the ABS sensor hole, if it is going to lube the wheel bearing or the needle bearings, or both, or nothing. If i don't have to seperate the hubs/knuckle, that would be a big plus. Thanks FTE!
I went to a local hardware store. The usual 7 inch pliers won't work, you need something atleast 9inch with a slightly angled tip. Also, on the 2005 and up there are no needle bearings, there are sealed ball bearings, so they are not repackable. There's a snap ring that holds them in the hub but I haven't tried to see if they are removable.
Johnis, you are partly right about the needle bearings in the 05 hubs. Due to failure of the needle bearings carrying the full load of the stub shaft on the 2004, Ford put a full roller bearing in there to compensate and moved the needle bearing to inside the accual 4x4 auto locking assembly that slides out with the auto/lock selector cover. I know this because mine just failed due to lack of grease. I was told that no replacement needle bearing is available(even from ford) and I would have to buy the whole 4x4 auto locking asssembly for $400.
I am pulling my hair out over the lack of help / knowledge, available info or photos from Ford or the web on these 05 auto locking assemblies and the hub wheel bearing assemblies. I've spent hours online, with tons of data available for the 04, but it was like the 05 design didn't exist until I found a picture in these guy's photo gallery. Need help, can I get the bearing seperate!
Yep, i tried to remove my sensor when i did my ball joints to lube the non-serviceable hub bearings, there was nothing wrong with them, i just wanted to top them off... ended up ripping the sensor in half... Basically ruined a perfectly good hub for no good reason.
SpringerPop
52
03-21-2016 09:36 AM
