Hopefully this week. I’m hoping to see a little quicker spool but still maintain the cfm as the previous turbo
you’ll def see faster spool with the 68mm turbine then you did with the 364.5/73
If I remember correctly the 64/68 sxr and 364.5/68 sxe share the same 68mm turbine and housing
Interested to see how the updated compressor trim and cover do.
Not with my injectors. I think it would be to tight. That’s my opinion anyway. I still have a sxe 63/68 brand new in a box. Shoulda tried that but time never allowed. Kinda glad I ended up not having installed it.
IIRC the center shaft/turbine wheel are the same, bearings same, exh housing same between SXE and SXR. Differences are comp housing and comp wheel inducer exducer ratio (and maybe some geometry changes but I haven't seen the wheel yet).
