Annual Reminder - Grease Your Front Unit Bearings!
It's late August, and time for the annual reminder to grease your 4WD front wheel bearings by shooting grease through the ABS sensor holes.
For you new guys, here are some reference threads:
https://www.ford-trucks.com/forums/8...bearingss.html
https://www.ford-trucks.com/forums/8...-bearings.html
https://www.ford-trucks.com/forums/8...pics-here.html
This year mine are getting the NLGI #2 blue Delo chassis lube grease.
This is NOT the 60,000-mile greasing of your front "needle bearings". Guzzle's maintenance pages covers that nicely. Click here.
Remember, this is for the 4WD guys that have front ABS sensors. You 2WD guys already can re-pack your bearings.
Almost 200,000 thousand miles on my right front unit bearing by using this method, so I believe it works!
Pop
Pop
Nope, not for me either. Definitely sounds like something that I will screw up for sure. I am real good at converting a $0.00 project into a $1000 repair. I guess next time my hubs go out I'll get the kind with the ABS hole and find some way to keep dirt from getting down in there.
....now where is my PSD list so I can add that sucker on there??? Actually, it is more of a 3 ring binder with tabs and illustrations than a simple list....
You can fix your abs light on the dash by stragetically placing a piece of black electrical tape over the light. Totally kidding of course.
TinyWonder
X2, I'll be tackling the spindle bearings too while I'm in there, thanks Pop..
