1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Abs sensor hole: Lubes wheel or needle bearings?
Old 07-14-2009, 09:30 PM
JIMRSX's Avatar
JIMRSX
JIMRSX is offline
Well, I am coming up on the time to do a needle bearing lube, and am wondering if I shoot some axle grease into the ABS sensor hole, if it is going to lube the wheel bearing or the needle bearings, or both, or nothing. If i don't have to seperate the hubs/knuckle, that would be a big plus. Thanks FTE!
Old 07-14-2009, 11:13 PM
ironmine's Avatar
ironmine
ironmine is offline
NOT the needle bearings. You have to seperate the hub from the knuckle to do the needle bearings.
Good luck.
Old 07-15-2009, 12:11 AM
Waltdog's Avatar
Waltdog
Waltdog is offline
of American machinists
Careful taking the sensors out of the hub, they have a bad habit of coming apart when removed. Also, Unless your hubs are squeaky clean removing the sensors will knock grit into the hole
Old 07-15-2009, 09:23 PM
JIMRSX's Avatar
JIMRSX
JIMRSX is offline
OK, Thanks for the clarification. I'll separate the hubs/knuckle to lube the needle bearings then. I think I might lube the caliper slide pins and change the front diff oil at the same time..
Old 07-16-2009, 09:23 PM
Johnis's Avatar
Johnis
Johnis is offline
I am doing my hub and balljoints, removing the hub isn't as bad as I thought. The funny thing is, it took my about 30 minutes to remove the wheel, brakes, and hub lockers, but it took me 2 days to find a big enough external ring plier that would work for the 06 F350.
Old 07-17-2009, 07:00 AM
JIMRSX's Avatar
JIMRSX
JIMRSX is offline
Where did you end up finding the proper c-clip-ring pliers at? I appreciate the info.
Old 07-17-2009, 07:42 AM
Johnis's Avatar
Johnis
Johnis is offline
I went to a local hardware store. The usual 7 inch pliers won't work, you need something atleast 9inch with a slightly angled tip. Also, on the 2005 and up there are no needle bearings, there are sealed ball bearings, so they are not repackable. There's a snap ring that holds them in the hub but I haven't tried to see if they are removable.
Old 04-26-2010, 10:25 PM
FordManiac76's Avatar
FordManiac76
FordManiac76 is offline
Johnis, you are partly right about the needle bearings in the 05 hubs. Due to failure of the needle bearings carrying the full load of the stub shaft on the 2004, Ford put a full roller bearing in there to compensate and moved the needle bearing to inside the accual 4x4 auto locking assembly that slides out with the auto/lock selector cover. I know this because mine just failed due to lack of grease. I was told that no replacement needle bearing is available(even from ford) and I would have to buy the whole 4x4 auto locking asssembly for $400.
I am pulling my hair out over the lack of help / knowledge, available info or photos from Ford or the web on these 05 auto locking assemblies and the hub wheel bearing assemblies. I've spent hours online, with tons of data available for the 04, but it was like the 05 design didn't exist until I found a picture in these guy's photo gallery. Need help, can I get the bearing seperate!
Old 04-27-2010, 02:50 AM
redford's Avatar
redford
redford is offline
Received 1,597 Likes on 933 Posts
FordManiac76, welcome to FTE.
Send a message to our favorite parts supplier, partsguyed.com. He's south of you in Washington. He can help you get what you need to repair your truck.
Old 04-27-2010, 07:25 AM
GUNNERDOG's Avatar
GUNNERDOG
GUNNERDOG is offline
Yep, i tried to remove my sensor when i did my ball joints to lube the non-serviceable hub bearings, there was nothing wrong with them, i just wanted to top them off... ended up ripping the sensor in half... Basically ruined a perfectly good hub for no good reason.
centsless
05-17-2024 07:59 AM
SpringerPop
52
03-21-2016 09:36 AM
01EX
09-30-2010 10:47 PM
smoky_diesel
08-24-2008 09:27 PM
underp2
11-07-2006 06:12 PM
Quick Reply: Abs sensor hole: Lubes wheel or needle bearings?
