Sponsored by: Real Truck
Battery Discharging
Old Apr 27, 2010 | 12:39 AM
sprintnut's Avatar
sprintnut
Question Battery Discharging
Truck sits in heated garage all winter and battery keeps draining. Last reading was 11.87 volts. Will not start sometimes. New Motorcraft battery last summer.
What tests can I do to find cause?
Thanks in advance for replys.
Sprintnut
2000 F350 V10 Auto 4X4 Lariat SC
Old Apr 27, 2010 | 12:56 AM
redford's Avatar
redford
FTE Leadership Emeritus
If the battery is holding a charge OK, then you need to look at the alternator. I'd take it off and have it tested at your local auto parts store.
As a quick test, take a voltage measurement, then start your truck. You should see a rise in voltage if the alternator is working.
Old Apr 27, 2010 | 06:28 AM
hanklin's Avatar
hanklin
on a side note, you might want to put a battery tender on it or at least start/drive once in a while
Old Apr 27, 2010 | 07:48 AM
SGnAZ's Avatar
SGnAZ
X2 on this.Good advice Hank
