A little progress today.....
Old Jul 28, 2009 | 03:26 PM
  #136
Brewtl's Avatar
Brewtl
Originally Posted by uncle.stosh
I'm toying with the idea of having my friend cut out their logo in 1/4" thick stainless steel on a water jet and then putting the letters on the front of the hood like F-O-R-D did in 1980.
Then maybe do F666 on the sides of the two front fenders.
More subtle, but very cool! Doitdoitdoitdoit!
Old Jul 28, 2009 | 04:33 PM
  #137
bill11012's Avatar
bill11012
Modular motor junkie
This sucks. I finally picked up the correct radius arm bushings yesterday, but was too tired last night after work to install them.
I have some extra energy today after work but it's 94 degrees out there right now!
Looks like "no bushings for you, next....."
It is 106 here.
can i come work at your place were it is nice and cool?
Old Aug 5, 2009 | 04:58 PM
  #138
uncle.stosh's Avatar
uncle.stosh
Well, I could not resist the temptation to get rid of the steelies and throw these 92-96 OEM aluminum wheels on. The price was just too good to pass up: $17 each.
I also scored a like new pair of Continental Touring AS 275/60R15's for $12 each. I put both of them on one side of the truck to see how it would look with fatties all the way around.
They are a little wide for the front and will rub the fender, so I'm going to buy a new pair of 225/70R15 Continentals to match. They are the same OD but about 2" narrower and should fit perfectly.
They look way better than the steelies and are a LOT lighter. The lightness of the wheel/tire combo will help tremendously with acceleration, braking and fuel mileage.
Once again, here is an updated pic with the new wheels on. Me likey.
I stared at the rear axle pretty hard today in an attempt to figure out what I'm going to do about dropping the rear. The "C" notch kit that I found on the Nite Edition truck is still there, but I'm not really liking the design of it. I think I'm going to need more clearance by the looks of it.
I was going to flip the axle on top of the springs, but now I"m not so sure. They make a front hanger that relocates the pivot point up a couple inches. Maybe I'll try that first and see how low it goes.
Old Aug 5, 2009 | 05:18 PM
  #139
uncle.stosh
I just found the bolt in kit that I was talking about from suicidedoors.com
Not bad for $59.
Old Aug 5, 2009 | 05:20 PM
  #140
girlwithatruck's Avatar
girlwithatruck
ooooooooohhh so pretty!!
Old Aug 5, 2009 | 06:20 PM
  #141
liftnw8z's Avatar
liftnw8z
For the price - I don't blame you a bit for putting those rims on. Looks a lot better.
Old Aug 5, 2009 | 06:35 PM
  #142
4caster's Avatar
4caster
I really like the "new" rims. I'm not sure how much I like the lowered look, but I'll wait to see the finished product. Are you still thinking of going seamless between the bed and the cab?
Old Aug 5, 2009 | 06:41 PM
  #143
uncle.stosh
Yep, but not sure how easy it's going to be to pull it off.
Right now I'm searching for a good frame. Mine is toast and I can't go too much further with what I have.
If I box the frame and add a couple of tubular cross members, I think it may be doable.
AbandonedBronco
Jul 18, 2023 12:30 PM
Evan_P
62
Apr 12, 2019 03:10 AM
ranger429
236
Jan 1, 2016 06:50 AM
AbandonedBronco
22
Jun 7, 2015 06:54 PM
Evan_P
21
Mar 2, 2014 01:27 PM
