Thanks for all the info on the K&N air filter. I will definitely look into that.
I just added the fluid to the rear end and almost half the bottle of the additive to see how it performed. OMG, that stuff stinks. I put in 3.5 quarts of fluid. The manual calls for 6.9 pints. How do you know if it's full? I don't recall seeing in the earlier replies if the '08 cover holds more.
No, it doesn't hold more. I only got 3 quarts of the RP in mine when it started pouring back out the hole! I guess I should check it again -- to see if there was some settling or something.
I was able to put all 4 quarts in before it started coming out of the hole. Everything seems to be good. Thanks again. My next projects are the crank seal? and re-packing the front bearings. Not sure if those are things I can tackle.
I've been searching all evening for the p/n for the fel-pro gasket for the rear diff that Scott had mentioned over in another thread. Here it is: RDS55394
