2008 Rear Diff Cover
Old May 24, 2009 | 09:08 AM
  #31
Izzy351's Avatar
Izzy351
I think Royal Purple is a good brand -- others here have used it successfully. I also have a buddy with a 150 that did his with that brand and no problems a year later.
I wanted the regular type to add my own, but NOBODY has it! I went three places before I found one that had 4 quarts of the RP. Two places had ONE.
But if you add too much modifier, you're clutches won't work at all and you'll have essentially an open diff. If you get chattering, add a little until it just stops and you should be good. I'm about to refill mine now and see how it does on corners.
Old May 24, 2009 | 02:16 PM
  #32
Izzy351's Avatar
Izzy351
UPDATE: Just went for a nice drive & got everything warmed up. No chattering, and no leaks.
Also got my oil change done, but as soon as I started filling it back up, it started raining. I never noticed how long it takes to put in 4 gallons of oil before. Nothing like a nice spring shower to make you take notice....
Old May 25, 2009 | 02:03 PM
  #33
ernesteugene's Avatar
ernesteugene
Originally Posted by Izzy351
I'll probably do the bead-blast thing and clear-coat it. I did that on a different project with aluminum parts that sit outside and it still looks great! Although I painted it with Ford Gray engine paint. They make it in clear as well, so that's probably what I'll use. I like the look of the plain aluminum cover.
A "flat black" high temperature paint on the cover will radiate more heat ENERGY and help to reduce the temperature of the diff oil!
Old May 25, 2009 | 02:47 PM
  #34
beanhead6D5's Avatar
beanhead6D5
Thanks Gene! I was painting my rear housing and stayed away from my cover because I thought that the paint would hold in the heat somewhat.
If I paint it I will use the high temp.
Old May 25, 2009 | 06:04 PM
  #35
TxFordGuy's Avatar
TxFordGuy
$23 for the 12 bolts isn't bad. i called FORD just for kicks to see how much they wanted for the factory bolts, $12/ bolt. thats $144 for just the bolts, i laughed at the guy telling them they were crazy, the dang cover only cost $60 from them. Do you have to put locktight and use lock washers?? i did mine last year and haven't had any leaks. Is it a common problem for them to vibrate loose?
Old May 25, 2009 | 06:13 PM
  #36
Izzy351's Avatar
Izzy351
I didn't use Loctite or lock washers, just flat washers. Since I used 1 1/2" bolts, some of them bottomed out just barely, so I threw an extra washer on as a spacer. I figure the Permatex will hold them in place. I guess we'll see. I have a look at them in a couple weeks and see if they've loosened up. Doubt they will.
I spent about $20 on bolts & washers, but mine are stainless. The ones from DM aren't.
Old May 25, 2009 | 06:20 PM
  #37
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I had mine powdercoated black in a crinkle type finish. Gets dirty but cleans up great.
Old May 25, 2009 | 06:34 PM
  #38
Izzy351's Avatar
Izzy351
Your stock cover or the '08?
Old May 25, 2009 | 06:57 PM
  #39
big poppa's Avatar
big poppa
Looks cover looks great Joe, sharp. I run the RP in mine, found it for 9.95, think it was a mistake but snagged it up. Anyways, I added a little Ford modifier to mine cause it was grabbing around corners, not bad but noticable, put it in and its been fine for about 15,000 or so , good luck..
Old May 25, 2009 | 07:00 PM
  #40
Izzy351's Avatar
Izzy351
Thanks, Mike! I saw SuperTech at WM for $9.95, but I just couldn't bring myself to put it in *MY* truck. LOL
Old May 25, 2009 | 07:35 PM
  #41
big poppa's Avatar
big poppa
You got it and I hear you, can't bring myself either to use that Supertech, no offense to those users though...
Old May 25, 2009 | 08:00 PM
  #42
Bigcat350's Avatar
Bigcat350
Looks great Joe. I want this cover also, Dang more stuff to do but i love it.
Old May 26, 2009 | 03:35 PM
  #43
ernesteugene
The high temperature part is just to accommodate the diff temperature so that the paint doesn't peel. Just to make sure that no one misapplies my suggestion let me give a little "Physics lesson" about why using "Flat Black Paint" on diff covers is appropriate and why the color black isn't appropriate for some other applications such as air filter boxes and turbo inlet tubes which unfortunately Ford decided to make black anyway!
When an object such as a diff cover is heated to a temperature Td by the hot oil inside each 1 ft^2 of the object radiates away heat ENERGY at a rate that's given by... R=(5.018x10^-10)(Ed)(Td+459.67)^4 Watts/ft^2 ...where Ed=Emissivity of the diff cover which is a ratio from 0 to 1 and Td=Temperature of the diff cover F.
For example if you've got a diff cover temperature Td=250 F and you assume Ed=1 the above equation gives... R=(5.018x10^-10)(Ed)(Td+459.67)^4=(5.018x10^-10)(1)(250+459.67)^4=(5.018x10^-10)(1)(709.67)^4=127.3 Watts/ft^2. If the surface area of the diff cover is 1 ft^2 then the cover radiates away 127.3 Watts. To put this into "RV heater" perspective 1 Watt=3.4 btu/hr so that 127.3 Watts=432.8 btu/hr and the standard electric heater that I use in my RV is 1,500 Watts which is 5,117 btu/hr.
The E=Emissivity is a physical property of the surface of an object and for Polished Aluminum E=0.04, for Black Anodized Aluminum E=0.88, and for Flat Black Paint E=0.91. So if you leave the diff cover shiny to look pretty it only radiates away (0.04)(127.3)=5.1 Watts but if you paint it with flat black paint it radiates away (0.91)(127.3)=115.8 Watts!
Well every little bit helps but it turns out that the additional 110 Watts of radiated heat that you gain by painting the cover black isn't all that much in the over all scheme of things because the 3 mechanisms for transferring heat ENERGY away from any object are radiation, conduction, and convection.
Since air is a good insulator conduction doesn't play much of a role and if it wasn't for the convective heat transfer to the air flowing across the diff cover, the diff cover temperature would increase to very high values of Td before the "(Td+459.67)^4 leveraging factor" in the "Radiation equation" would be large enough to let radiation carry away all of the heat that's generated inside the diff.
If you make an object black it not only radiates away a maximum amount of heat ENERGY but it also absorbs a maximum amount of heat ENERGY that might be radiated towards it from other object's in its vicinity. That's why an air box and turbo inlet tube should be bright and shiny or painted with a glossy white paint so that they reflect the heat ENERGY from the engine and exhaust manifolds.
Well in the case of the diff cover it's surrounded by ambient air with a temperature Ta and this means that a diff cover absorbs heat ENERGY that's radiated towards it from the surrounding air in an amount that's given by... A=(5.018x10^-10)(Ed)(Ta+459.67)^4 ...and if we assume an air temperature Ta=70 F and Ed=1 then A=(5.018x10^-10)(Ed)(Ta+459.67)^4=(5.018x10^-10)(1)(70+459.67)^4=(5.018x10^-10)(1)(529.67)^4=39.5 Watts.
This means that a black diff cover absorbs (0.91)(39.5)=35.9 Watts from its surroundings and it radiates away 115.8 Watts so that the net radiation from a black diff cover to its surroundings is 115.8-35.9=79.9 Watts.
A polished Aluminum diff cover absorbs (0.04)(39.5)=1.6 Watts from its surroundings and it radiates away 5.1 Watts so that the net radiation from a polished Aluminum diff cover to its surroundings is 5.1-1.6=3.5 Watts.
So now we're only talking about a 79.9-3.5=76.4 Watt difference between a polished Aluminum and a flat black treatment for a diff cover!
In general you can just combine the radiation R and the absorption A and write... Rn=R-A={(5.018x10^-10)(Ed)}{(Td+459.67)^4-(Ta+459.67)^4} Watts/ft^2 ...as the net radiation from the diff cover and to check this equation for a black diff cover with E=0.91 it gives... Rn={(5.018x10^-10)(Ed)}{(Td+459.67)^4-(Ta+459.67)^4}={(5.018x10^-10)(0.91)}{(250+459.67)^4-(70+459.67)^4}={(5.018x10^-10)(0.91)}{(709.67)^4-(529.67)^4}=79.9 Watts/ft^2 which for a 1 ft^2 cover is the same net 115.8-35.9=79.9 Watts that we got by calculating the R and A terms separately!
It's interesting to note that the emissivity of human skin is E=0.97 and that the surface area of the human body is about 20 ft^2 so that if you use a skin surface temperature Ts=90 F and an air temperature Ta=70 F and assume a human running around naked you get... Rn={(5.018x10^-10)(Es)}{(Ts+459.67)^4-(Ta+459.67)^4}={(5.018x10^-10)(0.97)}{(90+459.67)^4-(70+459.67)^4}={(5.018x10^-10)(0.97)}{(549.67)^4-(529.67)^4}=6.1 Watts/ft^2 ...and multiplying this by 20 ft^2 gives 122.4 Watts as the total net power radiated by a human under the assumed conditions which is more than the net 79.9 Watts radiated from a black diff cover!
Old May 26, 2009 | 05:50 PM
  #44
mueckster's Avatar
mueckster
I found 5/16'' x 1 1/4'' SS at Sears Hardware in their Hillmann bins. They were $1.50 each. They were hex head. They only had a few. Home Depot had the SS flat washers in packs of 5, but the price wasn't marked. I will check with a couple of other places that have Hillmann products and see what I can come up with.
Old May 26, 2009 | 06:01 PM
  #45
Izzy351's Avatar
Izzy351
Gene, what if you're in North Texas, let's say in July, and the ambient temp is 110, and the hot pavement is 250* radiating straight up at the nice black cover? Just curious.
