p1293 p1294 Injector High Side Open
So I did injector work, (replaced 2 and new O-rings on the other 6) when I put it all back together I am getting the codes indicated above, the truck runs but you can hear it is not quite right at low rpms, I am leaning toward valve cover gaskets and UVC harness, but have a tight budget, any other thoughts?
I would double check the large connector above the drivers side valve cover. IIRC it is a 42 pin connector. You could also use an ohm meter to check the resistance of the injectors at the 9 pin plug. Like Curtis said most likely a connection. Also, what codes/symtoms were you getting before you did the work? Good luck....
Burgess090906
04-18-2017 11:01 AM
Crewcab Turbo
21
06-10-2016 07:08 AM
MiamiPSD
02-06-2013 05:08 PM
