Part V
Old Feb 9, 2009 | 11:52 PM
  #3961
Powerstrokedlariat's Avatar
Powerstrokedlariat
My other woman is Amy Wynn from trading spaces. She is hot for one, but can build quite well and if you watch her she actually knows what she is doing. Oh, and come on, she wears a friggin tool belt!!! thats hot to me....
Old Feb 9, 2009 | 11:54 PM
  #3962
4inchlovin's Avatar
4inchlovin
Originally Posted by triskit16
Anyone watch CSI: Miami? P Diddy is on it...makes my skin crawl! What are they thinkin?!
I like CSI:Miami, NCIS is classic just for Abey and Zeba, But if House comes on im glued! Anyways hope everyone is doing well!
Oh and Lisa be kind to your behind we all like it! LOL
Old Feb 9, 2009 | 11:56 PM
  #3963
BabyBunny's Avatar
BabyBunny
The parents watch her all the time.
Glad everything is good on your end!
Im doin great. Goin on a job interview tomorrow. Need some extra money to pump back into my truck! Time for a DP and a few other things...oh yea...and bills!
Good luck on the interview!!
Old Feb 10, 2009 | 12:27 AM
  #3964
triskit16's Avatar
triskit16
Thanks! Its nothing life changing or anything but it is definitely extra $$$$
Old Feb 10, 2009 | 12:37 AM
  #3965
triskit16's Avatar
triskit16
Goodnight ladies and gents!
Old Feb 10, 2009 | 12:44 AM
  #3966
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Good night every one!
Old Feb 10, 2009 | 12:48 AM
  #3967
Powerstrokedlariat
I'm heading out too! Goodnight
Old Feb 10, 2009 | 12:57 AM
  #3968
4inchlovin's Avatar
4inchlovin
Me too! Night yall....
Old Feb 10, 2009 | 05:40 AM
  #3969
Izzy351's Avatar
Izzy351
Looks like I'm the first one up -- Good Morning peeps!!
Getting ready to head out. See y'all later...
Old Feb 10, 2009 | 05:54 AM
  #3970
Smokin''s Avatar
Smokin'
Smokin
I'm up too. Runnin around getting stuff ready to go. Gonna drive 800 miles today.
I'll probably chat with you all later on! Have a good day!
Old Feb 10, 2009 | 05:55 AM
  #3971
bdrummonds's Avatar
bdrummonds
Yep Im here too, heading out to work in a few minutes, have a good day all.
Old Feb 10, 2009 | 06:07 AM
  #3972
bdrummonds's Avatar
bdrummonds
Stole this from the Nation, but I can say I own and use all of these tools. Sometimes exactly as described
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal
Bar stock out of your hands so that it smacks you in the chest and flings
Your beer across the room, denting the freshly-painted part which you had
Carefully set in the corner, where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the
Workbench with the speed of light. Also removes fingerprints and hard-earned
Calluses from fingers in about the time it takes you to say, ''What The....??''
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes
Until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
Blood-blisters.
BELT SANDER: An electric Sanding tool commonly used to convert minor
Touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board
Principle. It transforms human energy into a crooked, unpredictable motion,
And the more you attempt to influence its course, the more dismal your
Future becomes.
VISE-GRIPS: Generally used after pliers, to completely round off bolt heads.
If nothing else is available, they can also be used to transfer intense
Welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of
Intense welding heat to the palm of your hand.
OXY-ACETYLENE TORCH: Used almost entirely for lighting various flammable
Objects in your shop on fire. Also handy for igniting the grease inside the
Wheel hub you want the bearing race out of.
TABLE SAW: A large stationary power tool commonly used to launch wood
Projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after
You have installed your new brake shoes, trapping the jack handle firmly
Under the bumper.
EIGHT-FOOT YELLOW PINE 2X4: Used for levering an automobile upward off of a
Trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
Drill bit that snaps neatly off in bolt holes thereby ending any possible
Future use.
BAND SAW: A large stationary power saw primarily used by most shops to cut
Good aluminum sheet into smaller pieces that more easily fit into the trash
Can after you cut on the inside edge of the line instead of the outside
Edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of
Everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably
Has an accurately machined screwdriver tip on the end opposite the handle.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and
For opening old-style paper-and-tin oil cans and splashing oil on your
Shirt; but can also be used, as the name implies, to strip out Phillips
Screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
Convert common slotted screws into non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket
You needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short. Works equally as well on
Boxes and thumbs.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used
As a kind of divining rod to locate the most expensive parts adjacent the
Object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard
Cartons delivered to your front door; works particularly well on contents
Such as seats, vinyl records, liquids in plastic bottles, collector
Magazines, refund checks, and rubber or plastic parts. Especially useful for
Slicing work clothes, but only while wearing them.
"DAMMIT" TOOL: Any handy tool that you grab and throw across the garage
While yelling ''DAMMIT'' at the top of your lungs. It is also, most often,
The next tool that you will need
Old Feb 10, 2009 | 06:10 AM
  #3973
AzBlueWolf's Avatar
AzBlueWolf
Good Morning All!
Good luck Tristan!
Safe driving Lisa!
Those heading to work, have fun, be happy you have a job to go to!
I am heading to the gym...gonna try for 3 hours today!
Old Feb 10, 2009 | 07:45 AM
  #3974
deereman4020's Avatar
deereman4020
Mornin' y'all
Old Feb 10, 2009 | 08:08 AM
  #3975
deereman4020
Jeez I might as well talk to my self since there ain't anyone else that wants to talk to me.
