Offroad & 4x4
Cheetos Crew Build
Old Dec 6, 2008 | 09:26 PM
  #76
teds74ford's Avatar
teds74ford
68. Back then, the suspension was like the Jeep CJs- shackles in front. They also had push-pull from behind the axle. Definitely dated.
The newest thing on it is the 91 Dana 60 front.
Hey, we are here to talk about your crew not my dodge
Old Dec 6, 2008 | 09:29 PM
  #77
Dave Sponaugle's Avatar
Dave Sponaugle
Cheeto with all the bolts you have in there, skip the weld.
I do like the cross brace with hitch reciever on both of the ones posted.
Makes for a good place to hook a recovery strap or have a winch mounted on a hitch insert so it can be used on either end.
The way you have it drawn out right now, I don't see much room for the cross brace though.
Old Dec 6, 2008 | 10:03 PM
  #78
crazyredneckanyhow's Avatar
crazyredneckanyhow
I have plenty of room between the frame rails for a cross brace. Like 25"+ -. I will have a hitch reciever in my bumper. I really wanna weld it also. The bolts holding it on will also hold the bumper on. It would be a pain to have to hold the suspension in place just to pull the bumper. Plus i wanna tie everything together in the front. Ive got a plan. Might try some mad paint skills to sho yall.
Old Dec 6, 2008 | 10:14 PM
  #79
crazyredneckanyhow
Ok i will brace the two pieces of the hanger at the front like this and add a crosspiece like this. He did his for a drop hanger which im not but using the same bracing idea.
Old Dec 7, 2008 | 06:43 AM
  #80
teds74ford's Avatar
teds74ford
I think he used box tube for the braces, so it reinforces the entire depth of the spring mount. Mine is only a plate across the front.
The beauty of almost any design is that it will be way more than strong enough.
Old Dec 7, 2008 | 11:22 AM
  #81
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
hmmmmm....
I wonder who's truck that might be?
Superbeast? Who would name there truck that?
Old Dec 7, 2008 | 04:16 PM
  #82
Dave Sponaugle
Cheeto, I can put you in touch with several guys that like mud.
There is a 79 setting in our shop right now getting a set of Rockwells under it with 44's on them.
Old Dec 7, 2008 | 04:58 PM
  #83
crazyredneckanyhow
PM sent Dave
Old Dec 22, 2008 | 07:49 PM
  #84
crazyredneckanyhow
Front mock up springs are in. Jsut needed to make sure everything lined up. Prolly gonna change the shackle mounts though. Still need to make the braces for the front
Old Dec 22, 2008 | 09:11 PM
  #85
Ryan50hrl's Avatar
Ryan50hrl
Those aren't the springs you'll actually be using are they????? that won't give ya a whole lot of articulation......LOL
Old Dec 22, 2008 | 09:26 PM
  #86
crazyredneckanyhow
Na im using new replacement highboy springs. Dont really need crazy flex. Its jsut a tow rig.
Old Dec 22, 2008 | 10:04 PM
  #87
Ryan50hrl's Avatar
Ryan50hrl
ahh...fair enough....
Old Dec 22, 2008 | 10:48 PM
  #88
1975StroppeBaja's Avatar
1975StroppeBaja
Looks like good progress Dave.
Have you replaced any panels in the kickpanel/firewall area? That is one solid truck. Looks nice
Old Dec 23, 2008 | 06:30 AM
  #89
teds74ford's Avatar
teds74ford
Not being critical, and maybe it is the camera, but does that make for a lot of castor? I am not that familiar with the leaf sprung trucks.
At any rate, looking good! So did you decide to bolt AND weld it?
Old Dec 23, 2008 | 11:07 AM
  #90
crazyredneckanyhow
No panels to replace. No rust at all.
Ted the front of the truck is actually about a foot higher then the rear so its not like it looks..
