paul,
i'm cool. if there is something that i know about or have ran into before, i just like to try and point you in the right direction on where to look or where to test. thats just the mechanical side of me. sorry! your brakes are hydrualic, but the booster side of it is or should be vaccuum. specailly on the diesels! they have a vaccuum pump that is belt drivin'. the diesels don't build vaccuum like the gas rigs do! which draws off of manifold vaccuum. thats why the diesels have a vaccuum pump! if that pump starts goin' south it will effect alot more then the 4x4 operation,brakes, heat and a/c,etc. i know you weren't ribbin' me. i was trying to give you some ideas on what to look for! i hope it these insights and ideas help!
thats what we had for heat back home too... good old birch. that stuff burns hotter and longer than anything. something about wood heat that warms you right through. not like this "air" temperature warm feeling that the gas furnace gives you...
