Spartan
Old Jun 29, 2008 | 02:52 AM
  #136
rollerstud98's Avatar
rollerstud98
can you still get x2's new?
Old Jun 29, 2008 | 06:52 AM
  #137
tex25025's Avatar
tex25025
The only way that I can think of now in order to get a new xcal 2 would be if you happen to have found somebody that is trying to clear out their supply to make room for the new stuff now.
Old Jun 29, 2008 | 01:31 PM
  #138
rbloodhound's Avatar
rbloodhound
I just tried the hybrid race. I didn't go far with it. All I can say is.....it's freaking awsome!
I can't wait to line up beside my friend that is running the superchip programmer. I will show him the tail lights.
Old Jun 30, 2008 | 01:29 AM
  #139
mxer0022's Avatar
mxer0022
sooo uuhhhh can someone enlighten me on which tunes are safe for a non studded motor? there are so many damn tunes my head is spinning...haha
Old Jun 30, 2008 | 08:37 AM
  #140
thedaddycat's Avatar
thedaddycat
Thanks Matt, I'm glad to see things are straightened out now. I was on vacation and just got back so I just saw the archive. I saved all the tunes except the Ultra Comp and will be playing with them.
Hey, I don't know if you got the word passed on to you, but as far as getting a 18 volt source for the new unit I had two ideas. First, if it does not draw too much power would it work by using a couple of 9v transistor radio batteries? Second, if you could tie in an adaptor for using the 18 volt battery from a drill driver (I have Ryobi but there are many others) that should have enough juice to do it and adaptors should be fairly easy to do.
Thanks once again for the archived tunes, my faith and patience has been validated and rewarded.
Old Jun 30, 2008 | 08:41 AM
  #141
tex25025's Avatar
tex25025
Most of his street tunes on down(tow, stock + etc) are going to be safe for a non-stud engine. When you start getting to the race files(particularly ultra comp) is when you start getting into the need for studs just to make sure. Now depending on how you play with the hybrid race, you could be alright. For sure, agg. street economy on down in power, you should be alright.
Old Jun 30, 2008 | 09:01 AM
  #142
OZX1's Avatar
OZX1
The Hybrid has very low cylinder pressures in light of the neck-snapping power that it produces. If the question was "what POWERFUL tune is SAFEST for my 6.0", I say the Hybrid is the best bet. It's "safer" than the ASE.
Old Jun 30, 2008 | 09:33 AM
  #143
ciscofreak's Avatar
ciscofreak
The Hybrid is safer than the ASE? I've been running the ASE as my daily tune as I thought it was safer than the Hybrid.
Old Jun 30, 2008 | 10:01 AM
  #144
mxer0022's Avatar
mxer0022
so what you're saying is pretty much all of them with the exception of the ultra comp are good to go and then the ASE is alright if used gently?
Old Jun 30, 2008 | 10:02 AM
  #145
tex25025's Avatar
tex25025
Yes and no(actually the no applies to all tunes, but I think it's more probable to happen with the higher hp tunes then lower ones). Yes it does have lower cylinder pressure, but you have to remember with the higher hp tunes your likelyhood of ragging on it before your truck gets to operating temp. also increases your odds of lifting heads. Now that applies even to a stock truck with no tuning depending on installation of the heads and some other factors, but I think that it's more then likely to happen with a higher hp over stock tune then it would be for tow tune, economy, street economy etc. the only tune that would rival the hybrid race and ultra comp tune for frequent ragging would be the aggressive street economy I believe(which leads to furthering this debate I'm sure).
Old Jun 30, 2008 | 10:10 AM
  #146
MIKESANDS's Avatar
MIKESANDS
Personally Hybrid Race is as far as I would go with an unstudded motor.
Old Jun 30, 2008 | 12:59 PM
  #147
duffman77's Avatar
duffman77
I think you are playing with fire on anything more than 70 or so HP. The consequences of a big $$$ failure are not worth runninng an extra 5% increase in power with the high power tunes.
Old Jul 2, 2008 | 08:13 AM
  #148
jwd1475's Avatar
jwd1475
Loaded the Ultra Comp file last night and went to the track for amature night. Wow!Lots more power than the Hybrid race tune. My best time in the 1/8 mile was 8.91@ 75.51mph. Very impressed. This was my first time to the track in 25 years. I felt like a kid again. There were only three other trucks there 2 Dmax's and one Cummins and they didn't do very well. The best was one Dmax with a 9.60. Thanks to Matt for putting the files on the web site. Otherwise I dont think I would have tried the Ultra Comp file. So it's back to ASE and Agressive tow for me, but I thik I will leave the Ultra Comp in the third spot on my X3 just in case.
Old Jul 2, 2008 | 09:34 AM
  #149
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Guys, if you have any requests for other files/codes to be added, please post it here.
Spartan Diesel Tech Support Forum
Old Jul 2, 2008 | 10:27 AM
  #150
cartmanea's Avatar
cartmanea
Thanks again Matt! Any chance you could post some tunes with EGR disabled?
