2 Cycle engine out as additive
Old Mar 6, 2008 | 10:50 AM
randomhero1172's Avatar
randomhero1172
Tried my first tank with 2 cycle engine oil. No - Not used oil, or used trans fluid. Just regular new 2 cycle engine oil. Idles MUCH quieter, overall much smoother and less noisy. I have always added PSDK but after reading two interesting articles and some advice decided to give this a try i have changed my mind. Take a look at these - This is what swayed my opinion about this additive.
General rule is - 1oz to every gallon
http://mopar.mopar1973man.com/2002%2..._cycle_oil.htm
- Read most of everything here - great science to back it up
http://www.johnfjensen.com/Diesel_fu...itive_test.pdf
- Most of you have seen this test - 2 cycle ranks as #7 on the test with good results similar to bio and XPD - Its also extremely cheap.
Any thoughts?
Old Mar 6, 2008 | 11:07 AM
nhill2090's Avatar
nhill2090
i too just experimented with the 2stroke oil. I bought the Super Tech ashless stuff from wally world. I only mixed a ratio of .5 oz to every gallon though. I wanted to experiment with the smaller amount first. Next tank, i may try a 1 oz:1 gal ratio.
I had been ready studies similar to the ones you posted and became interested. A cummins buddy of mine tried her out and saw a 2 mpg increase! I figured, what the heck might as well try it. 2 stroke oil is designed to burn.
alot of people will disagree with this, but to each his own.
Old Mar 6, 2008 | 11:14 AM
8tsixt's Avatar
8tsixt
I will be going to Walmart as well and pick some up.
Old Mar 6, 2008 | 11:15 AM
randomhero1172
Ya, maybe its a cummins thing! the first link i posted has good stuff from a "Mopar Guy". Have you seen or heard any difference so far? 2mpg?!?! Hmm that would be great but i doubtful. Im getting 13.75 hand calculated last tank. (some towing, alot of snow - some towing in snow!)
Old Mar 6, 2008 | 12:29 PM
Highmark18's Avatar
Highmark18
This is very interesting reading. I am curious to know if it makes a difference if you use synthetic 2-stroke oil or dino oil. Being I run synthetic 5-40 in the engine, should I use the synthetic 2-stroke? I am going to be researching this more. Makes sense to me...
Old Mar 6, 2008 | 12:50 PM
eatfish's Avatar
eatfish
http://mopar.mopar1973man.com/2002%20Dodge/Tips%20&%20Tricks/2%20cycle%20oil/2_cycle_oil.htm
Good site. I posted a link to the forum a few days ago and people blew it off. You are right, there is good research involved. Glad someone else sees the value of the site.
Old Mar 6, 2008 | 02:07 PM
Izzy351's Avatar
Izzy351
To me, the big question is how much does it cost per treatment? If I use one ounce per gallon, I would need a quart basically per tank. How much is a quart of that stuff? About the syn, I'm not so sure in this case if the difference between syn & dino would be worth it. I guess you could try a quart of each and see if there is any noticeable difference. Definitely let us know how it works out for you!!
Old Mar 6, 2008 | 03:40 PM
randomhero1172
I got 32Oz (perfect for me) of valvoline 2 cycle for 2.99 ... I think thats pretty good. Summer blend XPD may be a little cheaper. Its a lot less then DK, and much more benefit.
Old Mar 6, 2008 | 04:41 PM
PwerStroke99's Avatar
PwerStroke99
i first started using 2 stroke oil last year and i was averaging 12.5-13.5 mpg prior to it. now i am averaging 14.5-16, depending on how i drive it. i love it and put it in every tank! Im hoping to increase my mileage when i put my new injectors in this fall
Old Mar 6, 2008 | 05:08 PM
HP junkie's Avatar
HP junkie
Does your truck smoke more with the 2-cycle oil? It seems like something to try, just have to convince myself to do it.
Old Mar 6, 2008 | 05:25 PM
pullinair's Avatar
pullinair
I am with you on this . I would be intersted to see if I can run something like maxima's castor oil. The sweetest smelling 2 stroke oil on earth. (And it is a good lubricant)
Old Mar 6, 2008 | 05:33 PM
F350-6's Avatar
F350-6
Subscribing to this thread.
Please all post back with your findings and opinions.
Old Mar 6, 2008 | 05:48 PM
Highmark18's Avatar
Highmark18
To the guys that are doing it, approx. what ratio are you mixing it??
Old Mar 6, 2008 | 05:54 PM
fxstbchopper's Avatar
fxstbchopper
I have been thinking about doing this as well so I will be watching for some results as well so please post back what you find. I will do the same if I start using it.
Old Mar 6, 2008 | 06:53 PM
nhill2090's Avatar
nhill2090
this tank i mixed only a half ounce to every gallon of fuel..next tank ill try the full ounce to each gallon of fuel
it will be another few days before i can report back with any mileage gains (if any) on this 1/2 ounce tank. and another week after that for the full ounce tank. i was averaging abotu 11.8-9 mpg before with just diesel kleen
