Offroad & 4x4
Official Mall Crawler Spec Thread
Old Apr 10, 2008 | 07:20 PM
  #286
STGFordCrazy04's Avatar
STGFordCrazy04
Yeah I guess I have asked you about this before. I still dont understand it though. When .030 over stroker kits can be had for very close to the same money with the top of the line forged junk being better than any component in a 501s rotating assy could ever be.
I went with 1.7 ratio rocker arms because thats why Scotty recommended. I didnt need the higher ratio 1.73s or even 1.8s for my build because of the target RPM range....ie low as possible.
Other than that I honestly dont have a great answer for you. I wrote the check and he sent the "best bang for the buck" parts.
Old Apr 12, 2008 | 11:20 AM
  #287
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
well after catching up on the reading here, apparently i missed something important, as it sounds that nick's vacation is actually a temp ban? is that correct and if so, WHY?
Old Apr 12, 2008 | 12:54 PM
  #288
quadzjr's Avatar
quadzjr
just another Rockwell looser
i said a bad word.......apparently too many times............
Old Apr 12, 2008 | 02:05 PM
  #289
Truckin4life
oic, that blows... hopefully it wasnt that word...
Old Apr 12, 2008 | 06:58 PM
  #290
roger dowty's Avatar
roger dowty
Originally Posted by FTE Fred
oh... me...
Fluffy dice hanging from the rear view mirror, and shagpile seat covers!
now don't be screwing with my dice son...
or my '8 ball' shiftin ****...
or my wal mart tires.... and the almost soft feel of my delux, certified imitation sheep skin seat covers. hmmmm amost heaven or is that heaving...as in after a bad night of tequila and braughtwerst.
Old Apr 13, 2008 | 01:04 AM
  #291
Truckin4life
im gunna go with the heaving part. tequila is not so good anyway, but mixed with braughtwerst i can only imagine. I'll take my crown mixed with more crown or coke, either or. now the 8 ball shifter ****, i can stand. Would prefer an old lawnmower piston or something similar though, that would be way awesomer!!! and i just got an idear!
Old Apr 13, 2008 | 02:24 PM
  #292
roger dowty
Originally Posted by HighProCam
Haven't you already discussed this
Why a 1.7 rocker and not a 1.73?
Do you have any experience with the pedestal style roller rockers..... Trying to make up my mind on new heads or working the old ones myself
Nice TFS's...btw
i like the pedestal rollers thus far...put on first set on a 380+hp 400 build. The positive lock on them...sturdy compared to the studs...even if they're braced.
The primary issue with pedestal...when using aftermarket parts especially, is to get that geometry right and adjustment correct. Studs are much easier in that department. Using scorpion pedestal on the 400 i had to shim the rocker up to .080 to get the proper geometry and then ordered the pushrods...that really should have been different for int vs exhaust due to the valves i used...pain...but very stable.
The 1.70 rockers will affect lift obviously and that does affect power but the diff between 1.7 and 1.73 is only .009 with a cam lobe of .33". IMO the best way to get low end as far as 'breathing' is to keep the velocity of the charge as high as possible and breath well at low valve lift. thats why i went with a retro hyd roller cam...very steep.
i'm interested in learning why one would use a 1.8 for high rpm apps...never built a high rep motor. I assume it's to increase lift and thus flow without going too extreme with the cam lobe. ok...makes sense i think...with the cam lobe you have to maintain a lift to duration ratio and by using the 1.8 rockers you effectively increase lift w/o affecting that ratio and thus ramp on the lobe...right?
Using any rocker different than stock will screw with your valve geometry ie centering the roller on the valve tip so it travels correctly accross and back etc. It will be a bit harder to do with pedestal rockers but worth it imo. going with 1.8 or 1.7 (on a wheezer) I'd hit up the studs...big studs with a girdle. I was going to put 1.7's on a stock wheezer build in place of the 1.6...i had '65 289 4v heads ported etc sitting on it...even with studs i could not get the geometry even close without what i thought were rather extreme angles... wanted to see what that would do...think it would have been pretty cool. now i have a 260 cam to put in it.
Old Apr 14, 2008 | 06:58 PM
  #293
godblessmud's Avatar
godblessmud
Originally Posted by bigrey6306
heres a good one...
Not sure it has enough shocks for me...
Oh and please note the "best engineered" trophy!
eBay Motors: Ford : F-250 (item 230239408796 end time Apr-14-08 18:57:25 PDT)
lawl...32 shocks...bwahahaha!I will give props for running a carb...
Old Apr 14, 2008 | 10:23 PM
  #294
2kcrewcab's Avatar
2kcrewcab
This thread has had too much seriousness over hte past page. Bring back the QUAD roll bars!
does this fall into mall crawler territory? The tires look like they might give the BFG AT's a run for da suck!
It can even do 200MPH!!!!!
Description
GMC 1500 1/2 ton body,413 BBC 700R trans. tilt bed, Neons, 1 ton rears, Tranny cooler, custom stainless fuel tank, custom 4" frame, roller spring suspension, STREET LEGAL, all lights work, DOT bumpers, strobes,tannue cover,custom ladders welded to frame for entry, power windows, power locks,56x23 tires mounted on rimes with a 16.5 bolt pattern,duel oil filters, lots of fun to drive play with or take to car shows which is what I did with it, I have won several trophies, looking for best cash offer, I have over $40,000.00 in it, but I'm wanting to turn it I no longer have a place to store it, will also consider trades. custom headers with 5" muffler & 4" exhaust. hydralic assist steering.
Old Apr 14, 2008 | 10:28 PM
  #295
Truckin4life
that first one... is it a 4 banger, i see the headers only have to main pipes... wff?!?!?!?!?!?!????
Old Apr 14, 2008 | 10:29 PM
  #296
Truckin4life
yea im sure those ladders do alot of good while off road, thats one of the first things i see going by by... hi car roof, hi ladder, by car roof by ladder.
Old Apr 14, 2008 | 10:31 PM
  #297
godblessmud
Im diggin the suplus diamond plate monkey f*** of a front bumper...
And Quad roll bars aint gunna help when that 6" body lift (probably made with spare kitchen utensiles and whatnot) lets go and you slide off the frame into a tin can crumple...
  #298
crazyredneckanyhow's Avatar
crazyredneckanyhow
Quads truck with a chevy body?
Old Apr 14, 2008 | 10:35 PM
  #299
Truckin4life
actually i kinda liked the front bumper but i see it turned over and being a front bumper and a grill guard kinda thing to with proper cut outs for ventilation of course... That would be a numero uno priority on my mall crawler rig, 3 sheets of diamond plate for a front bumper AWESOME!
Old Apr 14, 2008 | 10:38 PM
  #300
godblessmud
2 pipes per side? WTF has a V4 in it?
