Offroad & 4x4
Official Mall Crawler Spec Thread
Old May 3, 2008 | 03:40 PM
  #346
quadzjr's Avatar
quadzjr
just another Rockwell looser
Originally Posted by MBBFord
plus, some times when you're stuck bad, you can't get to the hitch, much less the axle....
very true.......i'll have both on my truck
Old May 3, 2008 | 03:41 PM
  #347
quadzjr's Avatar
quadzjr
Originally Posted by 73f100shortbed
I don't think the axle being a tow point is a good idea at all either.
explain?
gd10cl
Old May 3, 2008 | 03:42 PM
  #348
Ryan50hrl's Avatar
Ryan50hrl
All i know is i've seen a rear axle get ripped out by attaching to it (of course it was a toyota)...i've never seen one come out from recovery from the frame....i think it comes down to you're putting ALL of the force of pulling through the mounting points, whether it be the four links or the leaf spring ubolts.. when you're pulling from the frame you're going to more evenly spread that force over both axles......I dunno...i'll stay with shackles mounted to the frame myself...
  #349
captain p4's Avatar
captain p4
pulling from the axle creates a moment about wherever the springs are attached to
pulling from the frame creates a moment about the axle if its STUCK.
If you're that stuck you'd probably be better off pulling from the piece that is stuck.. the axle.
but i'm about to fail my dynamics final, so don't listen to me.
Old May 3, 2008 | 03:45 PM
  #350
MBBFord's Avatar
MBBFord
Nick, I deffinatly understand your thinking.....
BUT, I've never seen any get pulled out by the hitch and leave their axles in the ground.
I have seen guys wheel a little rough and spit out lift blocks (even as small as 3") and rip their axle out from under the truck.
I could only imagin jerking on the axle being worst....
OF coarse the axle (shackles and stuff) could be beefed up enough to possibly be a reliable tow point.
  #351
quadzjr's Avatar
quadzjr
hahahahahahaha.........
Old May 3, 2008 | 03:47 PM
  #352
quadzjr's Avatar
quadzjr
it was on a TGW video, thats the only time ive heard of it........im not knockin the hitch approach, im just saying there is nothing wrong with hooking to your axle.......
Old May 3, 2008 | 03:50 PM
  #353
Ryan50hrl's Avatar
Ryan50hrl
another thing to keep in mind that it doesn't take alot of force to pop a tube out of the center section....i think the picture in mind was a rockwell...and that might be ok...but i'd be concerned pulling on an axle tube. IF you're gunna do it....it better be right at the spring/four link mount point
Old May 3, 2008 | 03:53 PM
  #354
73f100shortbed's Avatar
73f100shortbed
I understand the idea of why pulling from the axle might be good, but if it is stuck real bad I would think the frame would be a stronger point to pull from. I guess it just all depends. Someone go try it and see what works LOL. I would think it might strain the u-bolts and if they break you might get your axle back and leave the truck in the mud
Old May 3, 2008 | 09:07 PM
  #355
quadzjr's Avatar
quadzjr
4 link my good man.........4 link!
Old May 8, 2008 | 09:47 PM
  #356
2kcrewcab's Avatar
2kcrewcab
Superduty on 54's and Rocks. 5.4L engine... ugh... Only $40,000
Description
2003 f250 superduty 5.4 gas 77,ooo miles 2.5 ton rockwell running gear 54 boggers on 24'wide long wheels kingcoils ladder bar set up disc brakes truck has 40 inches of lift daily driver
Old May 8, 2008 | 09:51 PM
  #357
dragogt's Avatar
dragogt
Do they really expect somebody to buy that?
Old May 8, 2008 | 09:54 PM
  #358
2kcrewcab's Avatar
2kcrewcab
Of course... It's a "daily driver"
Old May 8, 2008 | 09:58 PM
  #359
dragogt's Avatar
dragogt
daily driver my left n _ t, and w/a 5.4 can we say dog? (I knew you could) lol
did I mention people are stupid.
Old May 8, 2008 | 10:04 PM
  #360
2kcrewcab's Avatar
2kcrewcab
If I had $40k, I'd buy it just to see the look on the guys face at the inspecion station to get it registered! haha It would be priceless. They could look at it from a mile away and see it was not going to be street legal!
I wanted to build something pretty close to this truck but with a stroked 460. I like the SD body style, throw some rocks under it and some big boggers. it'd be a fun toy!
