Sponsored by: Auxito
Navigator engine swap
Old Jan 7, 2009 | 04:48 PM
  #121
grandaddy's66's Avatar
grandaddy's66
Originally Posted by BURNSTOUGHFORD
...I dont understand what every ones thinking is with haveing to swap flex plates.
I was thinking the 99F250 had a different tranny in it, and therefore may have had a different flexplate
Old Jan 7, 2009 | 04:54 PM
  #122
grandaddy's66
Originally Posted by pdenbigh
If I want to avoid tuning the engine, can I just get the ECU from the donor truck and use it? Do you know if it plugs into the 4.6 harness ok? Or, should I get the 5.4 harness too and swap that as well...?
I realize I won't be getting max power, but if the ECUs will swap over (I can get the ECU for free with the engine) that seems like the fastest way to get my truck back on the road. Save me the money of the SCT + dyno time too...
Thanks a ton,
Peter
First, I don't think you can avoid tuning the engine. If you can't afford to do that, then I wouldn't do the swap. It's centrally important and I cannot stress it enough. It's not about max power, either. It's about proper engine function, timing, air/fuel ratio, various sensor arrays that ensure the engine is cooling properly, etc.
If you are taking the engine from a 99F250 and putting it in an Expy, I cannot imagine that the ECU's would be compatible without tuning it anyway.
Trust me when I say this: In the hands of a credible, experienced dyno shop, the $500-600 that you spend between the tuner ($250-350) and dyno time ($200-300) will be the BEST and SMARTEST thing you will do on this sway bar none.
Just get it tuned, whether you can afford to or not. Cut something else out, but not that.
Old Jan 7, 2009 | 05:00 PM
  #123
pdenbigh's Avatar
pdenbigh
Hi Jason,
Thanks for the reply. To clarify, the truck is a 2001 F150 and the engine will be from a 2003 F-150.
If I bring the ECU from the 2003 with the engine, why would I need to get it tuned?
Thanks man!
Peter
Old Jan 7, 2009 | 06:00 PM
  #124
grandaddy's66
OK.
I thought you were the guy with the 5.4 Expy swap. My bad.
I think what you propose will work, and it will save you money. Will you have to pay extra for the donor CPU? Do you know that it was functioning properly?
If it's cheap and is coming off a running vehicle, you might be as good as gold.
Old Jan 7, 2009 | 06:12 PM
  #125
pdenbigh's Avatar
pdenbigh
It's free and it's coming off of a running truck, the same truck that I'm getting the 5.4 from. The truck was totaled when it sideswiped a hill, and they drove the truck to the salvage yard. I think it's a good bet.
Thanks for all the advice Jason and Burns!!!! Couldn't have started this project without ya!
Old Jan 7, 2009 | 06:25 PM
  #126
grandaddy's66
keep us posted!!!
Old Jan 7, 2009 | 07:24 PM
  #127
truckeradg86's Avatar
truckeradg86
Sry I'm l8 lol
Old Jan 7, 2009 | 07:51 PM
  #128
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
If you swap the ecu over directly the truck will not start. The PATS system will detect that its not hooked to the same computer parts as before. Its built in so that people cant steal parts and resell them without ford reflashing the computer PATS.
So more than likley if you use the ECU then you will need to take it to ford to reflash the PATS. Probably wont cost more than 50 bucks but it wont drive untill then.
Its still the cheapest option.
Old Jan 7, 2009 | 09:15 PM
  #129
grandaddy's66
good call, Burns...
Old Jan 7, 2009 | 11:30 PM
  #130
truckeradg86
thats another one for fte! lol hey pdenbigh the hard your by can u get a cheep lower intake from the 99 54... and a fly of 5.4 to 4r70
Old Jan 10, 2009 | 08:12 PM
  #131
pdenbigh's Avatar
pdenbigh
Come again?
Old Jan 10, 2009 | 08:17 PM
  #132
pdenbigh's Avatar
pdenbigh
Progress!
The 4.6 is out! What a bear that was. By far the toughest engine removal I've done. Those top two tranny bolts are a pain!
Anyhow, only casualty was one little wire so I Call that a success. I do have a question though please:
The 4.6's flexplate has 6 bolts, whereas the 5.4 has 8. What's all the talk about swapping stuff around? Do I need to do something here?
Also, thanks a bunch for the heads up on the PATS. That would have driven me nuts!
We'll get an early start tomorrow so if you don't mind to post up a quick note about the flex plates I'd greatly appreciate it!
Take care,
Peter
Old Jan 10, 2009 | 09:01 PM
  #133
BURNSTOUGHFORD
If your 5.4l has a flex plate on it then just leave it. As long as it was bolted to a 4r70w to start with.
Ya the tranny can be tough but a bunch of extensions and coming from the back of the tranny by the tail shaft isnt to bad.
Old Jan 11, 2009 | 08:47 AM
  #134
dierks's Avatar
dierks
thats pretty cool swap congrads on getting it completed hope he gets it running the way he wants.
Old Jan 11, 2009 | 10:51 AM
  #135
truckeradg86
I still gotta get that lower intake and the flywheel hopefully ill be up soon...
