Sponsored by: Auxito
Navigator engine swap
Old Nov 14, 2008 | 04:12 PM
  #76
black02eb's Avatar
black02eb
Motor will be going in tomorrow morningand should be up and running by sunday evening. I will keep you posted.
Old Nov 15, 2008 | 10:16 PM
  #77
grandaddy's66's Avatar
grandaddy's66
black, make sure you get that thing tuned. Ken's 32V put down 168 rwhp baseline after install. He went a loooooooong way on the dyno
Old Dec 10, 2008 | 09:59 PM
  #78
truckeradg86's Avatar
truckeradg86
I love this thread soo all I need is alt no starter no ps for my 4.6 to 5.4 triton
Old Dec 10, 2008 | 10:42 PM
  #79
grandaddy's66
you got it
Old Dec 11, 2008 | 12:13 AM
  #80
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
grandaddy,
did you get rid of the navi swapped truck? Is it quicker than your new one?
Old Dec 11, 2008 | 08:07 AM
  #81
truckeradg86
i have gotten many responces to what parts have to be changed ill grab the alt since itll cost only 16 bux more lol thnx for the info grandaddy
Old Dec 11, 2008 | 09:24 AM
  #82
BURNSTOUGHFORD
You dont need an alt, they are the same.
Old Dec 11, 2008 | 05:21 PM
  #83
truckeradg86
what about the flywheel....... i have herd there are too diff ones and the 4.6 and 5.4 have diff ones and will be a problem and will have to take torq conv annnnnnddddd herd the tranz will shift all weird with the swap...... plz tell me these ppl are a$$ holes
Old Dec 11, 2008 | 08:37 PM
  #84
Bobby82490's Avatar
Bobby82490
You dont need a flywheel, you need a flexplate. The windsors and romeos use different bolt patterns.
Old Dec 11, 2008 | 09:25 PM
  #85
truckeradg86
Not to be a newb but what is a flexplate
Old Dec 11, 2008 | 09:32 PM
  #86
truckeradg86
So will the new engine have a flexplate on it or will I have to take off 4.6 and do I have to change torq converter for the flexplate change too
Old Dec 12, 2008 | 08:45 AM
  #87
Bobby82490's Avatar
Bobby82490
A flexplate is similar to a flywheel. Basically a flexplate is for a automatic and a flywheel is for a manual.
Old Dec 12, 2008 | 09:08 AM
  #88
BURNSTOUGHFORD
you wont need one if your engine has one on it. the only difference in the fexplate is amount of bolts to the crank shaft, if both engines had a 4r70w hooked to them then it doesnt matter. This is assuming your donor engine has a flex plate on it already.
My 5.4l that i got a had a flexplate (flywheel, same damn thing) on it already and it bolted straight to my tranny.
Old Dec 13, 2008 | 12:13 AM
  #89
truckeradg86
The 5.4 is coming from a f250 99 maybee I need the torq conv or no
Old Dec 17, 2008 | 09:25 PM
  #90
grandaddy's66
again, depends on the tranny. More than likely, you would need the flexplate for the 4r70w because I don't think 250's came with that tranny. BUT, if your Expy has a 4r70w tranny in it, then you should be able to use the flexplate from that.
burns, the 99 Navi truck is still in the family and it was quicker than my 05, but now that I have my CAI and custom tune, the power numbers are similar (same dyno, too) so I guess we'll have to touch em off and see, eh?...
