Sponsored by: Auxito
Navigator engine swap
Old Jan 11, 2009 | 02:58 PM
  #136
grandaddy's66's Avatar
grandaddy's66
Originally Posted by dierks
thats pretty cool swap congrads on getting it completed hope he gets it running the way he wants.
Thanks!
Oh wait. I don't even think this is my thread anymore.
Old Jan 12, 2009 | 07:04 AM
  #137
pdenbigh's Avatar
pdenbigh
Originally Posted by grandaddy's66
Thanks!
Sorry man...
The truck started last night! We used the 4.6 computer to just see if it'd start, and it fired on the first try!
I've been around a lot of loud cars, from rods to V8 American Iron racecars, and I don't think I've ever heard a sound as wonderful as a completely uncorked 5.4 in a 2 car garage. Since the exhaust doesn't mate up, it's running with just exhaust manifolds at the moment...
Today I'm going to weld up some adapters for the exhaust and take it for a gentle test drive.
Thanks again to all of the help guys. I couldn't have done this without your advice!
Best,
Peter
Old Jan 12, 2009 | 08:15 AM
  #138
grandaddy's66
No need to be sorry. I think it's great.
CONGRATS on busting it off! I think if you get the exhaust patched up, taking it for a gentle test run should be fine. It'll run (as you've seen), it just won't run right, or at least as right as it should. Just be careful, and keep the updates coming.
COOL!
trucker, you're next!!!!
Old Jan 12, 2009 | 09:07 AM
  #139
truckeradg86's Avatar
truckeradg86
oooooooo it runs off the 4.6 nice tell us how it does and how it runs so i know how dire it is 4 me 2 find a dyno.... there hard to find
Old Jan 12, 2009 | 11:02 AM
  #140
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
It will still run better than a 4.6l, i put 15k on my 5.4l with a 4.6l tune before i finally got the engine tuned. I pulled trailers and abused it and never had any issues with the 4.6l tuneing. I did install the 5.4l MAF sensor if that makes any difference. But i was running the 4.6l exhaust manifolds to. I still need to have a custom dyno run made for it though.
Old Jan 13, 2009 | 05:37 AM
  #141
truckeradg86
not to sound like a dumazz but if it isnt broke.... if itll run better than a 4.6 than why spend the 600 bux....
Old Jan 13, 2009 | 07:36 AM
  #142
pdenbigh's Avatar
pdenbigh
Hey guys,
The volumetric efficiency (VE) will be all screwed up if I keep the 4.6 computer in the 5.4. Since the 5.4 pulls more air, it will most likely run lean because the fuel tables will be calibrated for a lower displacement configuration. I don't want to run that risk. Thanks though.
The truck is getting the exhaust tied up this afternoon. I'm hoping to get the computer squared away this week. I'll report in on the result!
Peter
Old Jan 13, 2009 | 12:18 PM
  #143
truckeradg86
So I have to get a 5.4 comp for a 4r70 tranz around99 and get that tuned... god dam u gotta be kiddin me this is gettin pricey
Old Jan 13, 2009 | 01:48 PM
  #144
pdenbigh's Avatar
pdenbigh
You don't have to get a computer, just get a chip like the SCT or similar. With that you can burn any program you want onto your existing ECU.
I put in the 5.4 computer and I'm going to have the PATS reset for around $80. Doing this allowed me to keep the PATS which you can not do with an aftermarket chip (in this example). Later I can add an aftermarket chip and keep the PATS, which I will do when I have an extra $400. I got the ECU with the engine though so it wasn't an additional cost.
Old Jan 13, 2009 | 04:47 PM
  #145
truckeradg86
u guys know where i can get a comp 4 this setup... cheep
Old Jan 13, 2009 | 07:04 PM
  #146
pdenbigh's Avatar
pdenbigh
As stated above, swapping in a 5.4 ECU won't work because of the PATS system. So, you have two options:
1. Get a 5.4 ECU (Car-Part.com--Used Auto Parts Market) and get the PATS reflashed by a Ford dealership, ~$80 for the flash, ~$? for the ECU.
2. Get a chip, disable PATS, and reprogram your existing ECU to work with the 5.4, ~$300.
Good luck!
Peter
Old Jan 13, 2009 | 10:20 PM
  #147
truckeradg86
That put things into perspective thnx
Old Jan 14, 2009 | 09:53 AM
  #148
BURNSTOUGHFORD
If you use your existing ECU then you dont need to flash the PATS. Just retune it for the bigger motor.
Old Jan 14, 2009 | 02:19 PM
  #149
Johnny Langton's Avatar
Johnny Langton
Originally Posted by pdenbigh
Hey guys,
Peter
No, it doesn't work like that. The MAF measures the amount of air entering the engine, and the PCM uses this input to control injector pulsewidth to get the commanded air/fuel ratio. Displacement will be off,and therefore load calculation and the resulting spark calculation will be off,but it will not make you lean.
JL
Old Jan 14, 2009 | 05:16 PM
  #150
BURNSTOUGHFORD
JL
Hence the reason my truck ran for 15k pulling boats and trailers with no ill effects.
Thanks johnny
