Sponsored by: Auxito
Navigator engine swap
Old Dec 23, 2008 | 10:15 AM
  #106
truckeradg86's Avatar
truckeradg86
The ignition is diffrent on the 99 f250 coil at every plug where the 4.6 had to coils and 4 wires each side..... intake is diffrent and I broke the vaccume resivour (can't spell) lol
Old Dec 23, 2008 | 05:19 PM
  #107
grandaddy's66's Avatar
grandaddy's66
it'll still work. We used nothing off the 4V Navi engine where a 4.6 2V once lived.
All of the wiring harness was retained from the truck itself - plug wires, sensors, ECU, MAF the works.
Burns, I've never had the trucks to the track, so I can't lay it down for ya like that.
Old Dec 23, 2008 | 05:54 PM
  #108
Big Bad's Avatar
Big Bad
Originally Posted by grandaddy's66
burns, the 99 Navi truck is still in the family and it was quicker than my 05, but now that I have my CAI and custom tune, the power numbers are similar (same dyno, too) so I guess we'll have to touch em off and see, eh?...
I thought the 32V made 278 rwhp with a 98 Cobra air intake?
If that's the case, with a JLT type setup, 01+ lightning maf and a retune the 4V will probably lay down mid-high 290s.
Old Dec 24, 2008 | 06:33 AM
  #109
truckeradg86
ok ill try that out sounds easier anyways now i just need the fireing order if anyone has it seeing as i ripped the 2 coils out lol
Old Dec 27, 2008 | 01:39 PM
  #110
grandaddy's66
that would ROCK!!
but yeah, our torque numbers are similar and he has about 25 HP on me now, so I'm figuring I might get my butt beat.
BUT he's going to put an STS Turbo on it sometime in the first quarter, so he'll be kickin a whole lot more @ss than just mine
Old Dec 29, 2008 | 09:50 AM
  #111
truckeradg86
Does anyone know if my truck will run with the blk box broke under intake I cracked it and can't find a new one and don't think the 4.6 will go on plz help I'm stuckkkkkk
Old Dec 29, 2008 | 11:49 AM
  #112
grandaddy's66
IF it runs (probably not), it won't run well.
That black box is your plenum, and even if it does run (unlikely), that will be one nasty vacuum leak.
Old Dec 29, 2008 | 09:34 PM
  #113
truckeradg86
can i patch it somehow
Old Dec 30, 2008 | 03:15 PM
  #114
grandaddy's66
not likely, but I can't be sure. There's nothing that I know of that would make sense
Old Dec 31, 2008 | 07:54 AM
  #115
truckeradg86
I guess ill be picking one up...can someone post a pick of the coil packs and where the spark wires go I'm lost with that....
Old Jan 7, 2009 | 07:21 AM
  #116
pdenbigh's Avatar
pdenbigh
I'm going to try to summarize my notes for two potential swaps. My current truck is an `01 F150 with the Romeo 2v 4.6 (with 0 compression in #3 )
Option 1: 2v 5.4:
2003-2004, spark plug problem fixed
Stock 4.6 harness will work
Needs some exhaust work, or get the 5.4 y-pipe
Keep stock ECU and get it tuned
-or, put in stock 5.4 2v ECU?
My Stock 4.6 transmission is a 4R70W - What does this equate to regarding the flex plate?
Option 2: 5.4 4v Intech:
What year to look for? 2001-2003?
It looks like the stock 4.6 harness will work?
-Or, get engine harness from Navi or blackwood?
Keep stock ECU but add an SCT tuner and have a 4v tune burnt
-Dyno time preferred, but not necessary since the tune has been established.
Exhaust work, or get the Navi Y-pipe
98 Cobra Intake will yield the most power
Grandaddy, others with experience, can you confrim that list and answer the few red questions please?
Thanks a bunch guys!!
Old Jan 7, 2009 | 07:49 AM
  #117
grandaddy's66
On the InTech questions:
year is correct - late 2001-2003 had 4V
4.6 stock harness will work & get it tuned
Dyno time is paramount to get it right
custom exahust work (not much) will be necessary. A Navi Y-pipe may work, I can't be sure. We used the truck's but modified it
You will need the flexplate off of your truck's 4.6
There were not a lot of dyno runs performed with different air intakes. Quite frankly, we think power is available there.
Old Jan 7, 2009 | 08:20 AM
  #118
pdenbigh's Avatar
pdenbigh
Thanks for the fast reply Jason! Really appreciate your help
I am a firm believer in dyno tuning. On my 2.3 turbo Merkur XR4ti racecar we went from 215 to 254 whp at 13psi in just tuning alone!
Old Jan 7, 2009 | 09:17 AM
  #119
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
if the 5.4l has a flex plate on it already use it. i did. My 5.4l flexplate hooked right up to my tranny with zero issues. I dont understand what every ones thinking is with haveing to swap flex plates.
Old Jan 7, 2009 | 10:07 AM
  #120
pdenbigh's Avatar
pdenbigh
Guys,
One more quick question (I'm replying here so you see it) - it actually relates to a 5.4 2v swap from a 4.6 2v. The 4v engines are just too pricey for me right now.
If I want to avoid tuning the engine, can I just get the ECU from the donor truck and use it? Do you know if it plugs into the 4.6 harness ok? Or, should I get the 5.4 harness too and swap that as well...?
I realize I won't be getting max power, but if the ECUs will swap over (I can get the ECU for free with the engine) that seems like the fastest way to get my truck back on the road. Save me the money of the SCT + dyno time too...
Thanks a ton,
Peter
