Whining Power Steering Fix!!!
Old Dec 26, 2014 | 04:50 AM
  #211
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I think Motormite sells cap/dipsticks for Saginaw pumps.
That's the same company as Dorman/HELP.
Page 137 of their catalog...
#82581 looks correct. (you need to check the fit yourself)
https://www.dormanproducts.com/catal...nal.pdf#Page=9
Old Dec 26, 2014 | 05:30 AM
  #212
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Originally Posted by redneck832005
Is there a different looking saginaw pump other than pear shaped? Thanks for any info.
There are some Saginaw pumps with an oval shaped neck.
You know, you could take a picture of yours, and do a Google image search.
visit whatever page pops up and you will likely find info there.
Maybe this question could be better answered in the Dentsides forum?
Old Dec 26, 2014 | 07:12 AM
  #213
Scndsin's Avatar
Scndsin
...Is there a different looking saginaw pump other than pear shaped? Thanks for any info.
If you look at the pic I posted, note the circular pump area & how it "sits" in the "can" reservoir. Most look just like that. There are variations in the shape of the reservoir with some being remotely mounted and the "can" part being just big enough to enclose the pump. Take a look at a Summit catalog for some ideas.
Old Dec 26, 2014 | 04:57 PM
  #214
andyman1's Avatar
andyman1
WOW! Thank You! You Rock!
Old Jan 12, 2016 | 06:54 AM
  #215
Gore0199's Avatar
Gore0199
power steering whine
I was wondering if someone could give me the part numbers I would need to perform the conversion. The number listed in the above feed does not exist any longer. So I guess I would need the power steering pump number and the pressure hose number. I have a 1996 F-150 5.0 L
Old Jan 12, 2016 | 10:03 AM
  #216
Scndsin's Avatar
Scndsin
You convert to a 92 (?) & up E series van power steering bracket from a small block engine.
Here is the most recent thread:
https://www.ford-trucks.com/forums/1...-question.html
Old Apr 25, 2019 | 05:43 PM
  #217
McLeod's Avatar
McLeod
I have one of the 20-6244 pumps that is running low on power.
I know that they no longer make them.
I had heard that NAPA has a pump rebuild service, but after checking with my local NAPA they have heard of no such thing.
The yards around here have almost no 90's vans in them now to rob the Sag parts off of.
Is there a rebuild kit for the 20-6244 (part #?) ??
or
am I going to be going back to a C2 original type pump?
Thanks
Old Apr 25, 2019 | 11:50 PM
  #218
Scndsin's Avatar
Scndsin
I gotta believe they're pretty similar internally from one to another.
My best guess is look for a kit that covers late a 70s Sag in a Ford kit, maybe from Rock.
Old Apr 26, 2019 | 10:28 AM
  #219
McLeod's Avatar
McLeod
The problems of venturing away from replacement parts...
And most of the kits only include o rings and seals.
Mine doesn't leak externally.
What would cause a lack of pump power?
Wouldn't there be a problem with the pump vanes?
I have never had a steering pump apart before.
Old Apr 26, 2019 | 12:05 PM
  #220
Scndsin's Avatar
Scndsin
Yep. Murphy will definitely jump in the front seat.
My best guess would be excessive clearances or whatever regulates pressure.
I've not had one apart. Certainly there's a re-builder in your neck of the Great NW.
Have a look here:
https://www.google.com/search?q=sagi...hrome&ie=UTF-8
Old Apr 29, 2019 | 12:13 PM
  #221
McLeod's Avatar
McLeod
This weekend I decided to take a look at my 20-6244.
It had been a while since I changed fluid, so I set out to do that.
After disconnecting the return line, I discovered that I totally forgot that I had installed an "inside of the rubber hose" type of insert filter and, after removing it from the hose, the filter was nearly 1/3 plugged.
I cleaned the filter insert with brake clean and reassembled with new MercV fluid.
I regained some power in the pump by taking these steps.
So now I should be able to get a few more years out of this pump.
I did discover something though.
I Googled for local steering pump rebuilders to no avail.
I was going to check w/ RedHead (a local to me company) to see if they had any recommendations.
Two names prominently appeared. Lares and Cardone - neither local- but they have Rebuild and Return programs in which your local parts house will send your pump to them for a rebuild.
I'm surprised NAPA didn't know this when I contacted them.
I sent Cardone an email asking if they can rebuild a 20-6244 in spite of the fact that it is discontinued.
This is their response:
Thank you for e-mailing us. The only thing I can suggest is that there would be a good chance that we can remanufacture the unit you have. If you do decide to do this you would have to deal with a store that participates in our Rebuild & Return program.
I never inquired about cost, but it sounds as if they can rebuild the pump. You just need to deal with one of their participating retailers. It looks like many of the parts stores do participate, so check with your local store and the program is Rebuild & Return Service (R&R service).
Old Apr 29, 2019 | 04:12 PM
  #222
Scndsin's Avatar
Scndsin
Thanks for the information.
Old May 1, 2019 | 07:24 AM
  #223
Lowdog's Avatar
Lowdog
Okay, I have read through this thread a couple of times and understand that the Cardone/Napa conversion pumps are no longer available. So, if I understand correctly, to put the Saginaw pump on my "97 F-250HD with a 351W engine all I need is all of the parts off of a serpentine belt Ford van that has a Saginaw pump (with a similar engine, 302/351) and maybe a new pressure hose? I have the tools and the ability just need to know what to look for.
Old May 1, 2019 | 08:28 AM
  #224
Odisvan's Avatar
Odisvan
I wanted to say thanks for this post and ideas. my 84 was annoying like a cross between a cat in heat and an old police car siren. Flushed my pump and filled with ATF and only heard couple of extremely short and barely noticeable whines in test drive. Almost totally gone now. I'm amazed....
Old May 1, 2019 | 09:03 AM
  #225
McLeod's Avatar
McLeod
I think you want an early 90's econoline with the same engine family (serp belt front dress) as what you are swapping on to.
I never did the e van swap, so maybe someone better informed will chime in
