View Poll Results: Would you like a tech article on how to re-wire your factory harness to MAF?
Yes, I would
496
95.02%
No thanks
0.77%
I duno, I might...
22
4.21%
Voters: 522. You may not vote on this poll
SD to MAF Conversion - Write up?
Old Nov 4, 2008 | 12:42 PM
  #196
Conanski's Avatar
Conanski
Originally Posted by BroncoRoadKill
The problem I cant figure out is if I have to to convert to obdII to get the maf.
Both trucks you have are OBD-1 so OBD-2 never enters the equation. In very simple terms all you have to to is lift the engine harness of the mass air motor and put it on your running truck along with the MAF meter and computer.
Old Nov 4, 2008 | 12:57 PM
  #197
92 Black Nite's Avatar
92 Black Nite
Thumbs up
I would like to see a SD to MAF conversion writeup, it would definitely be beneficial for my 92 EDO4. To do cam and other upgrades..The people on here are very helpful with great information. Thanks Guys
Old Nov 4, 2008 | 01:41 PM
  #198
guitarnik's Avatar
guitarnik
i would jump at this if i knew how but im not that great with computer stuff so thiswriteup will greatly welcomed. i just need to know something. he said hes going to write up a non computer controlled article. so does that mean carbed or just that the mass air is not comp controlled.
Old Nov 4, 2008 | 02:48 PM
  #199
Lumpy87's Avatar
Lumpy87
Probably means just swapping parts including the ECM but not reprogramming it or replacing any chips.
Old Nov 5, 2008 | 08:46 PM
  #200
BroncoRoadKill's Avatar
BroncoRoadKill
Not so, my 95 is obd1 and the 96 is obdII We always plugged the snap-on under the dash of the 96.
Old Nov 6, 2008 | 07:18 AM
  #201
guitarnik's Avatar
guitarnik
has anyone done a writeup on this before at all? i would think that someone has seeing as how much interest there is
Old Nov 6, 2008 | 07:38 AM
  #202
Conanski's Avatar
Conanski
I would love an article cause I have a 95 f-150 with a 300I6 and m50d thats sd and a parts 95 withe same engine and tranny thats maf.
This is what your original post said....
Old Nov 6, 2008 | 04:42 PM
  #203
EPNCSU2006's Avatar
EPNCSU2006
Have you seen this: bjoern.brembs.blog: Content / Ford F150 302 V8 Pickup truck (2000-2003) / - Mass-Air conversion ? Granted, it's written about an 88 truck, but the wiring changes are all pretty similar and it does give a good idea of what is involved. Remember that the lightning throttle body and intake manifold modifications that are pictured on that page are not necessary.
Old Nov 12, 2008 | 12:58 PM
  #204
badasbrnc's Avatar
badasbrnc
Sorry guys to keep this thing goin. I just talked to Ron Reader from Dunn Rite Perf. and he said hes branching off and starting a new company Triple R Sales. They do stock the SD to MAF kits 795 for a standard. New phone # is gonna be 248-672-7250. Said he had about 200 in stock.
Old Nov 13, 2008 | 02:02 AM
  #205
jarod17's Avatar
jarod17
OK dumb question here but... How can you tell if your truck has SD or MAF?
I am pretty sure mine is SD but I have a '93 F-150 parts truck and am working a deal on parts off a '90 something F-250 from one of the local tow yards. How can I tell if these parts trucks are SD or MAF? Both trucks have E40D trannies.
Old Nov 13, 2008 | 04:27 AM
  #206
EPNCSU2006's Avatar
EPNCSU2006
The easiest way is to look for the mass air flow meter in the intake hoses. The air filter housing on mass air trucks will have a single outlet opposed to the double outlet of speed density trucks.
Old Nov 13, 2008 | 12:12 PM
  #207
BroncoRoadKill
Typoe, must have missed that. the 96 is maf with obdII
My 95 is sd with obd I
Might look into splicing the maf stuff into my harness, but just want to get my ducks in a row cause I don't want to endup with 2 parts trucks.
Old Nov 13, 2008 | 12:23 PM
  #208
Conanski's Avatar
Conanski
Typoe, must have missed that. the 96 is maf with obdII, My 95 is sd with obd I.
Though so.. and that throws a hugh monkey wrench into your plans because the 2 systems are not compatable. You can use the MAF meter and injector wiring if you strip it from the '96 harness and patch it into the '95 harnss, but the '96 computer won't even plug into your '95 harness so it's of no use at all.
Old Nov 13, 2008 | 02:56 PM
  #209
jarod17's Avatar
jarod17
So in that casee couldn't Bronco take the entire harness and computer from the '96 and put it into the '95?
Not trying to argue, still learning.
Old Nov 13, 2008 | 03:02 PM
  #210
Conanski's Avatar
Conanski
It would have to be the entire powertrain wiring harness, engine and tranny, and possibly the dash wiring and gauge pod as well. Not a small job.
