View Poll Results: Would you like a tech article on how to re-wire your factory harness to MAF?
Yes, I would
496
95.02%
No thanks
0.77%
I duno, I might...
22
4.21%
Voters: 522. You may not vote on this poll
SD to MAF Conversion - Write up?
Old Feb 8, 2008 | 02:22 PM
  #136
Conanski's Avatar
Conanski
Originally Posted by jburke832
The only things I have planned for the 460 are headers and low flow dual exhaust, a throttle body spacer, and K&N high perf filter.
Why not use a stock 460 computer then?
Old Feb 8, 2008 | 02:33 PM
  #137
jburke832's Avatar
jburke832
I was going for sequential EFI with mass air. I thought all of the 460 stock ecm were speed density(bank fired). Can you point me in the right direction
Old Feb 8, 2008 | 03:07 PM
  #138
Conanski's Avatar
Conanski
You're right.. I don't think there were any mass air/SEFI 460's. My suggestion to use the 460 computer is because..
A) You don't need mass air for the mods you have planned.
B) I think you'll have a better performing motor with better drivability using the stock 460 computer than you would with an SEFI 5.0 computer unless you spend the extra $$ and get it tuned.
If you were doing enough to the 460 to require bigger injectors(heads and a cam) then I would strongly suggest you do a mass air conversion and get a tuner. But for your relatively mild buildup you'd have to invest quite a bit of $$ and time in tuning just to get it run as good as the stock batch fire system.
Old Feb 8, 2008 | 03:17 PM
  #139
jburke832's Avatar
jburke832
Thank you Paul. I apreciate the input.
Old Feb 16, 2008 | 10:06 PM
  #140
GrimOne's Avatar
GrimOne
Well now my question is what is exactly the threshold that the SD system can handle? I'm planning a fairly mild build for a 460 which basically consists of porting the heads and intake (if possible and if necessary. Though I hear the breathing flaws rest more on the exhaust side) and an RV cam (along with headers, dual exhaust etc). I'm not aiming for a speed demon. not aiming for something that needs a radical cam profile or over sized injectors Just something with a bit more grunt than stock. Can a SD system handle those kinds of mods?
Old Feb 17, 2008 | 09:06 AM
  #141
frederic's Avatar
frederic
SD system likes anything that doesn't impact the vaccum signal in the manifold - meaning no to minimal overlap.
At least with the stock code/data.
Old Feb 17, 2008 | 10:43 AM
  #142
Conanski's Avatar
Conanski
Yes. The stock computer is calibrated for 24lb injectors which will support about 340HP at 80% duty cycle, so you can make ANY modification you want including porting heads and installing a larger cam as long as the motor maintains near stock vacuum signal quality. The vacuum signal is largely determined by the cam, it must conform to specs that include at least 114 LSA and no more than 216 degrees intake duration at 0.050". A cam with specs outside this will cause all sorts of driveability problems on even a stock motor.
Old Feb 17, 2008 | 05:33 PM
  #143
WTRBKT55's Avatar
WTRBKT55
Originally Posted by lmd91343
I have an '89 f150 302 with an AOD tranny. I also have an M-9000-T50 MAF conversion kit. The kit is designed for a manual tranny. The T51 is designed for an AOD.
Can I modify and use the T50 kit? The PCM is for a production '93 mustang with a strategy of A3M1. Only the function of pin 30 (NDS) is different between the two systems.
I could return it and get my $500 back.
I hope I did not hijack this thread.
Thank you,
Lance
Did you ever get a answer to your question about using the M9000-T50 kit for yourt AOD Truck. I''ve got the same situation and I've spent hours reading all the MAF conversion posts and couldn't find the answer to this question. Can the M9000-T50 Ford Racing MAF Conversion Kit for 87-93 F150 5.0L Trucks with a manual trans be used on a truck with a AOD trans? If not, what change(s) need to be made? If the ECM is the only difference what ECM can I use with the rest of the Ford Racing Kit. Any hel;p would be appreciated>
Old Feb 17, 2008 | 10:17 PM
  #144
Conanski's Avatar
Conanski
Yes you can use it.
Old Feb 18, 2008 | 08:10 AM
  #145
WTRBKT55's Avatar
WTRBKT55
Originally Posted by Conanski
Yes you can use it.
Thanks for replying so quickly. What changes do I need to make to get it to work in an AOD rtuck since Ford Racing says it's to be used in a manual truck?
Old Feb 18, 2008 | 09:21 AM
  #146
Conanski's Avatar
Conanski
No changes. The AOD is not computer controlled so the computer has no influence on it.
Old Feb 18, 2008 | 10:16 AM
  #147
FilmGuy's Avatar
FilmGuy
Auto computer on a manual?
I am preparing to do a MAF conversion on my 91 5.0 manual truck. I was able to get a good deal on a MAF computer from a 95 truck with 4R70W. Will I be able to use this on my truck? Or will it throw a code when it doesn't see the transmission?
A couple of months ago lmd91343 among others were talking about using some of these 4R70W computers, but I am not sure if they were just talking about using them with an E4od .
Thanks...
Old Feb 18, 2008 | 11:50 AM
  #148
devja71's Avatar
devja71
If I'm not mistaken, the main diff between the t50 and the t51 is mainly in the kickdown linkage nothing really to do with the computer. But someone pls correct me if there's more
Old Feb 18, 2008 | 12:04 PM
  #149
ssidney's Avatar
ssidney
there is ALWAYS valve overlap, sometimes more, sometimes less...but it's always there
Old Feb 18, 2008 | 01:42 PM
  #150
devja71's Avatar
devja71
If I'm not mistaken the main diff between the t50 and t51 is in the aod Kickdown linkage nothing really to do w/the computer but someone pls correct me if i'm missing something
