6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Mpg
Old Jun 27, 2007 | 10:46 AM
  #451
origcharger's Avatar
origcharger
"I used to have a gas motorhome and hated when diesel pusher fly by me going up the grade and still got 10 to 12 mph when you talk to them about there MPGs"
Perhaps those diesel pusher guys were not telling you the whole story about their fuel mileages?
Old Jun 27, 2007 | 10:55 AM
  #452
origcharger
"soon as I put it in park it went to regen 1250 rpm so the next one someone tells me that my truck will not do that because it was hot from towing and the heat generated from the stress of towing the trailer will not go to regen then he is going to be insulted from me in this web site because this the segond time that this happened to me the first time was going up the grade about two month ago right in the the middle the speed dropped and the I felt I lost half of the power and now this trip as soon as pulled to refuel it did it. please do not ever think that you truck will not go to regen when it is working hard as it will it does not care and the fact that someone commented before that there is no way it will go to regen while working hard is false false false this the segond experience for me so I do not care wheather your are pulling 20k pound or going up 20 mile 10% grade the fact that truck is working hard very hard does not mean it is burning the soot in the cats and when the computer tell it clean up it will, not caring what the hell you are doing."
Not that it necessarrily applies to Ford's version of the 6.4, this is how International describes the regeneration process on their version of the engine in their new school buses;
"WHAT IS REGENERATION?
Regeneration is the oxidation of soot particles in the diesel
particulate filter. There are two types of regeneration, passive and
active. Passive regeneration occurs when exhaust temperatures
naturally get hot enough to burn off particulates caught in the
DPF, cleaning the filter. Active regeneration is performed when the
exhaust temperature is not high enough to activate the process
of oxidation on their own. Fuel is injected into the exhaust system
and oxidized to increase the exhaust temperature and activate the
regeneration process in the DPF. Active regeneration can only occur
when the bus is above 20 mph."
Old Jun 27, 2007 | 11:20 AM
  #453
crazcorkath's Avatar
crazcorkath
In the summer I'm getting about 19 with mixed driving empty. 2001 srw 4x4 sc sb 6 speed with 3.73 rear. Only modification is K&N fipk.
Old Jun 27, 2007 | 12:06 PM
  #454
Enomra's Avatar
Enomra
Doubtful!!!!!!!!!!
Old Jun 27, 2007 | 12:16 PM
  #455
jvoigt's Avatar
jvoigt
What Eng? Miles? size of tires? I know the 6-speed manual might get slightly better milage then the Auto but 19mpg is more like pure HWY driveing.....um I dont think any 7.3L would average that with 50/50 HWY and city driveing.
Old Jun 27, 2007 | 12:52 PM
  #456
mattebury's Avatar
mattebury
Originally Posted by Admin
Cruise killed 2/4 MPG while you towed.....maybe even a bit more....
I don't know if I believe that. It may be true in hilly areas, but on the flat...
Having an engineering background, I'd want to see the data.
Old Jun 27, 2007 | 12:59 PM
  #457
mattebury's Avatar
mattebury
To help monitor fuel mileage, it'd be nice if Ford would give you the option for an instantaneous MPG readout on the dash like my wife's LEXUS as well as the average since you last pushed the reset.
I know it's not perfectly accurate, but directionally, having your current MPG would help.
As it stands now, I use it just for that seeing if I can get the display to give me an extra 10th towards the end of the tank. For me, I know I can reset for every trip, but I like to see what I'm getting off the tank.
Old Jun 27, 2007 | 01:44 PM
  #458
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I am the data and it kills MPG...
Old Jun 27, 2007 | 02:24 PM
  #459
Enomra's Avatar
Enomra
I have seen as much as .5-.7 mpg difference when using the CC vs not. I think the Admin is also adjusting his speed in relationship to the terrain and that will make a huge difference. I am comparing the steady speed CC VS steady speed not using the CC.
Old Jun 27, 2007 | 04:34 PM
  #460
crazcorkath
That is not using the overhead console, by the way, and don't forget I am a female. If my son drives the truck it drops drastically!!
Old Jun 27, 2007 | 04:38 PM
  #461
jvoigt's Avatar
jvoigt
That excuse doesnt work around here haha
Old Jun 27, 2007 | 05:08 PM
  #462
IB Tim's Avatar
IB Tim
I am with you...good story...stick with it....just when the son is not around...stand on it and have fun.....then .....
Old Jun 30, 2007 | 10:24 PM
  #463
alremkin's Avatar
alremkin
In this month's issue of Diesel Power(DP) there's a comparison of the 6.8 L gas engine and the 6.4 L diesel. DP found that the difference in the cost of fuel would pay for the diesel in just under 4 years but they used 19.27 mpg in their test. After reading what's in this thread, I re-did the arithmatic using 16.0 mpg for the unloaded diesel milage and got that it will take a bit over 5 years using the diesel to break even on the extra initial cost of the diesel engine. I hope some of the mechanical wizzards here will commnet on this.
The other thing I noticed in DP is that there was a big difference between the estimated milage of some of the trucks with the same modifications. In one case it was 6.5 mpg the difference between Nick Disse's truck on page 132 and Scott Lellich's on page 133. That seems like a big difference in estimated mpg.
Old Jul 1, 2007 | 05:10 AM
  #464
IB Tim's Avatar
IB Tim
That is why I stated …MPG is critical to driving style. Tires, gearing….HUGE
Old Jul 1, 2007 | 10:28 AM
  #465
diesel_dan's Avatar
diesel_dan
Here's a link to another thread on this, also I did some numbers on the 6.0 vs 6.8 that are a bit more real, but still end up with the same answer...
https://www.ford-trucks.com/forums/6...-hp-tests.html
